Ok. My first is now playing. Sound from both channels and the music sounds pretty good.
I need to do a real listening - a/b with my Luxman amp. Not a lot of time to do so tonight.
Things I notice.
[Edit, I figured this one out. it is picking up a signal from my wireless router] First is a concern. With no music playing and the volume on the Lux up @ 50% I start to hear a steady 'thump thump thump' at about 2 thumps a second. It does get louder with the volume control.
Second is that with it just sort of sitting on a cardboard box in the open it seems to be a bit 'microphonic' wrong term but close. When I reach in, to flip a dip switch, I start getting a ground hum before I touch it. Somewhere around 1" to a half an inch away. Should I be searching for a shielded box? Or maybe better wiring between the RCA females and the board?
There is also a good amount of static/hiss at high volumes when no music is playing that disappears when the unit is switched off. This happens with the wireless router off and the modem off as well. I expected silence with batteries. I suspect that this could be more cross talk being picked up from somewhere. Any ideas?
I'm new to external phono stages. Where do I ground the turn table ground to? It is currently running to the table but that is preventing me from moving the PS away from the 'rack' to see if the thump is something that it is picking up from outside the system I have turned off everything near it except the amp and the cable box/DVD.
