Finally I built a very nice twin mono phonostage
by myself, its a 1963 professional broadcast cirquit-Design
(BY RIM RADIO COMPANY MUNICH) using 4 selected European type
low noise Germanium Transistors per channel (8 in total for Stereo)
for voltage I built an external twin Mono Sulzer Borbely regulator.
The sound of this NBV (newly built vintage) -phonostage is breathtaking clean, crisp, deep in stage, smooth on voices and sax...
Listening to Diana Krall with this RIAA System is a pure pleasue.)
you will need pretty expensive boutique stuff (maybe with tubes) to do it clearly "better".
Gain is not too high so best use slightly higher output MM system.
Thats the Phonostage for one Channel using only the finest vintage components
(discretly built like an old tube amp with point to point wiring instead of a cirquitboard )
For coupling and decoupling I used finest russian 400 Volts paper in oil mil spec tin sealed caps and german made
"Beyschlag" carbon low noise resistors from the 60s and 70s. (Selceted by hand to closest tolerances)
I really wanted that original sound of the 60s out of these RIAA fuzzboxes
Twin Mono sulzer-Borbely voltage Regulator for ultra quite 24 Volts DC
Regulator case
Transformer and rectifier box using 4 discrete
ultra fast - lowest drop "Schottky Diodes" per Channel
(Whole Rectifier also dual Mono)
First filterstage CRC using a horde of small 220uF (fast) capacitors instead of
giantly oversized caps...so alltogether +- 2000 uF per Channel is widely enough for only 4 small
signal transistors per Channel....no need for 20.000uf giant cap stuff here...
works, no hum, no noise
ready for installation
(The black transformerbox finally also got its cover - after a week staying open for voltage and heat checking...)
Best regards from Germany
Willy
