BTW - I replaced the $2 USB cable on my keyboard with a new $60 one from Audioquest.
Really? I don't think so.
I choose to listen to people and hopefully share with them the facts.
I'm certainly glad people MUCH smarter than me did this in the past (else we may still believe the earth is flat), and I do it with any discussion that has opposing sides (religion, politics, AUDIO...).
I only ask for proof, of which no believers in magic can seem to supply.
Mr. Pig, I would gladly accept that your liquid-filled fuses improve sound quality if YOU could prove that you could consistently hear the difference between fuses.
(Could you describe a testing method that would allow you to do this that would prevent you from knowing the "proper" answer in advance?)
I would then scientifically show you that the improvement was due to some type of "defect" or fault with the non-liquid-filled ones that was preventing them from doing their proper job in the first place.
Remember, if something is an improvement, then whatever is improved was WRONG.
The letters that I see in my post look just like the ones I sent through my cheap USB cable.
Damn.
when I get the time I will do this for you. I believe I can place control and test fuse in a bag and select randomly from them. if i do it behind a screen that also covers the rear of the dAC, then I won't know which one I installed. I can either put it back in the bag and randomize, or put the second fuse in and wait until I listen to both to compare the results. There is no one here to randomly swap fuses for me, neither the dog nor cat have that skill. So that is as close to a DBT as we can get. If its not good enough, then its too bad.
I am curious to know how you prove the component is flawed, since you will not have access to it.
Regards
Mister Pig
Ahh you DO have a sense of humor about this whole thing!
You stated a DBT is not a valid test, then told me you can prove your ability to tell the difference with a DBT!
This place is fun!
What I did say is that proponents of DBT testing never seem to use the test to select their own audio components. Which from your own admission is true in your case too.
It's not a practical way to shop for gear, indeed it's probably an impossible way to shop.
Interesting blog http://nwavguy.blogspot.com/search?...d-max=2013-01-01T00:00:00-08:00&max-results=5, especially info about the McGurk effect.
Apparently I did not get this point across. I never said DBT testing was invalid, or that I disbelieved in it. What I did say is that proponents of DBT testing never seem to use the test to select their own audio components. Which from your own admission is true in your case too.
Actually while we are at it. Can you tell us what DBT tests you have participated in? As a supporter of DBT I would think you would have participated in them. How many of them have you managed to do?
Oh I will do what I can to get an unbiased test of the fuses for you. I have spent long enough listening to them to give it a shot. I just need to free up a couple of hours to do this, think I can get it done at the beginning of next week.
Regards
Mister Pig
I just skimmed the first few paragraphs & I'm hooked.
Thanks for the link!
A quote or two from the article:
"Studies show you can play the identical track on identical equipment at an identical level two different times and odds are extremely good people will hear significant differences if they’re expecting a difference. This is called expectation bias and it’s the brain trying to be helpful by filtering your hearing to match your expectations—"
and
"Neurologists, brain experts, hearing experts, and audio experts all agree the human hearing system, by necessity, discards around 99+% of what arrives at our ears. The brain is actively involved in what gets discarded. For example when you’re listening to someone at a noisy restaurant, the brain does its best to deliver just their voice. And, multiple studies show, when you’re listening to audio gear the brain also does its best to filter your hearing in the way it thinks you most want. If you’re expecting Gear A to sound different than Gear B the brain filters each differently so you indeed hear a difference even when there isn’t one.
:yes:
Not only is it a spirited debate but many points made. Have been reading every post in this thread (and several others like it) . . .
So far here's my answer . . .
http://www.youtube.com/watch?v=wKExj1TyP3Q
I wish this was true.... ...IF the addage of "hearing is believing and believing is hearing" is true, the Bryston SHOULD of sounded better than my 25 year junior Luxman amp, but didn't. There was no preconceived bias here. Just "what if". And believe me, what a shock.
And related, there is no "brain filtering" on the fact CDs ripped to my iMac played through my DAC compared to the CD played on the CD player I have with expensive cable is a no brainer: the iMac source is better. I would EXPECT the CDP with expensive digital interconnect to sound better but that is not the case. No expectation bias working here. Simply listening for the best sound possible.
Personally, I think expectation bias is a copp-out for those who don't take the time to listen and actually think about what is going on. Expectation bias, to me, is the easy way out; an excuse that in fact is used for not actually doing the test yourself or not paying attention.
One person being ripped off of their hard-earned money this way is too many.
I have absolutely no argument that you could be hearing differences and having preferences (and there's no reason a 25 year old piece of equipment can't sound better than a new one).
I'd be nuts to try to refute it (and would be willing to bet that there are measurable results to back up what you hear).
IF however, you tell me you listened to two IDENTICAL files on your Mac and are sure one sounds much worse because it arrived via the internet but the other was ripped by you (remember - IDENTICAL files, bit-for-bit), then I'd play the B.S. card.
Until you could prove your statement (pick the "bad" one out in valid testing with consistency over MANY tests), the B.S. card would remain firmly in play.
NO magic tweak has ever been proven to be effective (meaning CHANGE the sound, not necessarily IMPROVE it) in a legitimate test.
If they had, they would no longer be a magic tweak, they would be a "repair" (and the price would dramatically drop. Magic is much more expensive than reality).
Don't think of expectation bias as a cop-out.
Think of it as sleight-of-hand (performed on you by your mind).
The sleight-of-hand artist will CONVINCE you that he has thrown the coin up in the air (you may even believe you see it on the way up), only to have it vanish.
The reality is that your brain caused a perception that was entirely false.
The same thing can (and does) happen in the audio world, and it's been PROVEN time and time again.
You just can't refute proof.
However, you CAN create false truths and spread them around a lot in the hopes that people will just blindly believe them (and maybe even give you money for them).
Why do these false truths in audio bug me?
Because they are a rip-off. If a rich guy wants to waste his money, fine.
But there are plenty of people who work on a shoestring budget that end up wasting money on magic that could have gone to better primary equipment or to their music collection (a $4,000 tube amp to listen to CDs ripped at 128k on an iPod? Seriously?).
So you're our audio superhero. Out to save us all from things we've debated a thousand times.
