I suppose you've never seen an ad for a B.S. product in an audio mag?
You've never had someone knock on your door to convert you to their way of thinking?
Never had a salesman claim that x device is better than y simply because his commission was higher on the y device?
Heck there are people on this thread that ARE promoting the use of magic as a valid way to improve the sound of a system.
It's just that when it comes to brass tacks, none of them can ever seem to prove it.
(Mr Pig has liquid filled fuses in his DAC that sound better than the regular ones. He stated DBT was not a valid test method, then offered to prove he could hear the difference by performing his own DBT. Huh?).
To those who prefer things not be discussed and that music just be listened to: Please do so. And enjoy the heck out of it! It's what you like.
I find discussion and debate to be a great way to learn things and share ideas and a great way to keep my mind alive.
Is it OK if I do both (listen to systems AND discuss/debate them)?
I am no longer going to be nice about this. Quite simply you are a troll, and not as stupid as you appear. I will state this once again, I have never in one of my posts said that DBT is not a valid test. All I asked was, as a supporter of DBT do you use the test personally? Yet you choose to twist words and lie. From post # 54
A question if you don't mind. I ask this to people who are advocates of DBT testing, it is interesting to know the results. Did you use DBT testing to buy every component in your audio system? Is this a philosophy you actively practice? If so, can you tell us how you accomplished this, and to what means you chose your perspective candidates. Also how did you know you made the best purchase? What was your control or reference component?
I have yet to meet an advocate of DBT testing who actually practices it, you would be the first. Hope this is the case.
Another point about DBT discussions are how good is the control system? How non intrusive to the sound that the switching gear is. High quality switching systems are quite expensive, and it is a serious impediment to performing a proper DBT test. F
or the record, I believe the test does have value, but in my mind it is not the end all to an evaluation of audio gear.
Now there is your proof. Quit lying and distorting what others have said. But then again, as others have said, it appears you are a troll whose intent is to create disharmony.
Since you want to refer to the liquid fuse passage. Here it is again, and my opinion regarding tweaks.
Yes I also do agree that tweaks, set up, or even matching dissimilar compo
nents..ie..synergy....are appropriate fixes for a poorly designed piece of equipment. But what SOME of them do is shade the sound of a system in one direction or another, and provides some tune-ability to the end user. Some footers and isolation devices do this, and there is good solid science to back up how they effect a system.
But for the most part your list brings up the hilarious audio tweaks, and while they may have some following, I suspect that very few of them have large followings. But I have no interest in going through the whole list again, its a topic that makes the rounds here at AK.
But for what its worth, I have been using several sets of liquid filled fuses. So that should give you a good belly laugh, and discount whatever I have experienced in this hobby. So feel free to chuckle away.
Point out where you see that I believe in magic and sorcery. It isn't there. What you are is a liar and a twister of words. Plain and simple.
Mister Pig
