Vincent D
Vino.
Hi John,
I mean, if I connect a CDP to the Optical Digital input, and then I select "Digital 4" which is the Optical Digital input, and then select "Digital Direct" the indicator on the volume control will light up,( as it should) but sometimes it Doesn't. ( If I selected it, and then selected another Analogue source 10 times in a row, it would only light up about 4 times out of 10) That's why I suspected a bad contact on the "Digital Direct" selector.
"Try this , with a tuner connected to all except the phono have source direct and exercise all inputs , then exercise source direct on and off." I've already tried that, and with analogue sources if the selector is set to "Digital Direct" I get sound to both channels, but its a very Bright sound and not normal. Again with analogue sources if I turn "Digital Direct" off, I only get sound from the right channel.
When I loosen the tension screws on the gears should I see a gap between the bottom of the gears and the pcb? because when I loosened the screws before it made no difference, and the gears were still sitting tight to the pcb. Do I maybe need to loosen the screws and then gently prise the gears away from the pcb so I can clean underneath it?
