MX-2000 vs B-2
The MX-2000 is a MOSFET design and at first glance is an 'all out' implementation (copper clad & shielded chassis, heavy duty binding posts, large meters, 22000uf caps, extra large heat sinks, rosewood side panels, machined-not stamped-titanium case, 61 lbs, etc) but on closer look the B-2 (in my opinion) is superior. I say this based on comparing them physically as I haven’t done a side by side listening comparison. The MX-2000 is capable of 130w RMS per channel into 8 ohms @ .005%THD or 180w RMS per channel into 4 ohms @.01%THD. My pair of JBL 2226’s are high efficiency but are 16ohms and need the extra power the MX-2000 provides so I relegated it to subwoofer duty right off the bat. On the other hand the JBL SU1500’s (designed and built by JBL for Revell for use in their Sub1500) are not as efficient but are 4ohms and as a result, they need the extra power as well continuing to dictate that the MX-2000 by the subwoofer amp.
The differences I see between the two is mainly in the power supply. I believe the power supply is the key to amplifier performance/dynamics. The MX-2000 has a single power transformer and two 22,000uf power supply storage caps for a total of 44,000uf so both stereo channels are fed by a single power supply. The B-2 has two separate power supplies. Each side has a power transformers and two 18,000uf power supply storage caps per side for 36,000uf or 72,000uf total for side. The B-2 has almost twice the power storage capacity supported by two power transformers. This reservoir of power is a significant factor contributing to the dynamic performance of the B-2, that’s not to say the MX-2000 is a slouch, (again I haven’t compared them side to side) but on paper the B-2 has it beat hands down in addition to the VFET outputs.
Prior to acquiring the B-2’s (which I coveted since I heard them when they first came out but could afford) I had a pair of Yamaha M-4’s. They we good, but didn’t have the punch and effortlessness the B-2’s had. As a result, I build a pair of outboard capacitor banks (complete with soft start etc.). One bank had 240,000uf of storage and the other 272,000uf of storage in addition to the 20,000uf (I think it was 20k?) onboard in the amps. The result was a punchy, solid pair of amps, the B-2’s were only better at the top end of the frequency spectrum. I sold them when I acquired the B-2’s and the guy who bought them called me a few months later to thank me again. Nothing I’ve heard through the years has the sweet sound of the B-2, vintage SS/tube or new so-called ‘high-end’ (where there is more money devoted to ‘cosmetics’ and ‘style’ than in electronics or electronics design).
