did you figure this out? Did you start a new thread? If yes, send me the link.Minor detail: All worked well the last time I ran the C-4. I received my LEDs, pulled the case and front panel, and disconnected the bad bulb at the power switch. Plugged the unit back in to figure out which LED lead goes to the red & white wires, and I now have no power at any of the bulbs. I used to hear a relay click 3-5 seconds after I push the power switch - now I hear nothing. I cycled the power switch a number of times and checked for power at the switched outlets - all good. Checked the four fuses by the power transformer - all are good. What should I be looking for next?
the short version is: If your power source for the light bulbs is somehow shared with the RC timer for the relay time delay, there might be an adjustment that needs to happen on the RC timer to account for the difference of current required for the LEDs vs the old incandescent bulbs. Typically you would just have a screwed up timing with maybe a pop in the speakers. But...it can get more complicated.
Start a new thread or send a link tot he one you have already opened...if you are still in need of help.
