So far my schematic is this:
This is not a final version as I need to update the resistor going to pin 7 of 6AN8 as 1.5M and to pin 6 as 27K, add some resistors to the input and get rid of one of the filter caps, as there are only 3 in the supply filter. And I'm sure some other things I missed, but just wanted to make sure it makes sense so far. Do I have that diode in the negative bias supply facing the right way? (The negative everything-backwards thing trips me up)
Also, in the process of tracing wires, I think there are 4 x 35mm jacks on each of those cathode connections to ground - I'm guessing a fancy way to measure the cathode current for each output tube? One of them seems to have no actual connection to the ground. That seems like a bad thing for one side of a push-pull, no?
Skiz shows Mullard 5/20 topology, not Williamson.
Right, Laurent topology.Well, no, it's a "Dynaco" circuit, pentode voltage amp to triode cathodyne phase splitter. Mullard would be pentode voltage amp to long-tailed pair phase splitter.
Got crossed up.
Brilliantly elegant simple P/P driver ckt using bog-common small-signal triode/pentode television tubes.Oh, that's what it's called! Thanks, I didn't know that.
Great job so far! Comments:
1) Yes, I think you have the diode backwards. ;-)
2) That feedback resistor seems very low in value, like by a factor of 10. Maybe 1800?
3) Resistor to pin 6 of the 6AN8 should be 270K, not 27K. That's way to low a load for the pentode, I think. Check again?
4) Looks like he took some shortcuts in the PS, eliminating the choke filter. Shouldn't be a problem, I suppose.
5) The jacks would have been a way to insert an ammeter in the cathode circuit to balance the output tubes. They would normally be a closed connection. Certainly would be worth checking to make sure all cathodes are grounded with the jacks in normal (closed) position. Ideally, you'd want to insert a 10 ohm resistor between each cathode and ground to measure the bias current of each tube individually. Repurpose the test jacks to measure DC volts across each resistor to ground for biasing.
Some amps use similar ckt with 12AX7 dual triode.
postage stamp molded caps - btw are those mica or paper?)
probably mica, though that basic style did exist in paper cap. Sometimes you can tell by the dots, but not all of them used the first dot for type and just went straight into the value. Fair bet if its in the feedback circuit or a cap+resistor to ground off the pentode plate its some picofarad value, and most likely mica. If it comes out to be something like 0.01uf, then I'd expect paper but usually those are physically much larger.
The Laurent driver is sometimes considered sort-of a simplified Williamson. I guess because its typically direct coupled like the first tube in a Williamson. Instead of having more gain between the inverter and the output tubes though, it does it all in one stage with a pentode vs using what amounts to two medium gain triodes in series.
I think of It as a simplified Mullard P/P.probably mica, though that basic style did exist in paper cap. Sometimes you can tell by the dots, but not all of them used the first dot for type and just went straight into the value. Fair bet if its in the feedback circuit or a cap+resistor to ground off the pentode plate its some picofarad value, and most likely mica. If it comes out to be something like 0.01uf, then I'd expect paper but usually those are physically much larger.
1) I knew it!
2) Brown-grey-brown-silver, that's 180ohms 10%? (check the third pic in my first post - that's the big resistor next to the postage stamp molded caps - btw are those mica or paper?) I'll trace that line again for any other resistance in series that I'm missing. Btw I'm not finding that 680Ohm to the ground either... Does it make a difference that they are lifting the feedback at the 8ohm tap (yellow) instead of 16(orange)? Given the info in #4 below your estimate seems right on the money though, so I'm confused.
3) Red-Purple-yellow-Silver = 2-7-0,000 right you are, 270k 10%
4) So given the similarities, I think this is actually a tweaked Dynakit Mark II circuit featured here: https://worldradiohistory.com/Archive-All-Audio/Archive-Audio/50s/Audio-1956-Sep.pdf#page=58
it does not seem to feature a choke filter supply, just the el-cheapo CRC.
5) I've heard of this mod before and I like the solid direct path to the ground at all times much better than relying on the jack ground leaf to make a perfect connection every time.
Oh, wait, I see what you're saying about the missing 680 ohm resistor. But I think that's just a safety load on the output to ensure the amp doesn't see no load at any point. He probably eliminated it, it's not used in the Mark IV or ST70, which also employ a 1K feedback resistor. But I could be wrong and 180 ohms is what he intended. Just seems too low to me.
