Sorry, this is going right over my head. But I do thank you for the effort it takes to explain and for the knowledge that you have accumulated and are willing to share.
I sort of understand why feedback but not how it works. I’m thinking you take a portion of the output signal, feed it back into some point in the circuit, usually a cathode of a previous stage and because the signal is essentially inverted, it cancels out distortion but also part of the signal. Too much feedback and it does what - stops giving you distortion improvements but saps your signal? I understand that 1k is a customary value for this type of amp(and I’ll probably go with that), but for teh sake of my own understanding why didn’t they do that initially? Can there be another reason why they’d do that, maybe to control oscillations? Here’s a crudely traced circuit:
The hidden end of the 680 goes to pin 9, and 47 to socket center lug ground.
And at least in theory I should be getting 180+680= 860Ohm - is that close enough to 1k or no?
794Ohm seems to be within 7% spec of the 10% resistor tolerance and 752 Ohm is at 12.5%, though you did say the caps in circuit would skew this a bit. Is this considered to be out of spec?
Also would this 42 Ohm difference in resistance between the channels and therefore the amount of feedback be audible?
Would it make any difference if I replace these resistors with metal oxide ones?
