I own a pair of Cerwin Vega AT-100's that were first produced in Germany during the late eighties. My Cerwin Vegas have the same drivers as yours but with better tweets and mids that are also adjustable and my CV's are just as rare as yours. The max wattage they can handle before blowing a fuse is four hundred watts and they can be played at lower volume levels but only by a high watt/amp receiver. I've taken on Polk Audio Studio Monitor Tower speakers, JBL 250ti's and Yamaha NS-1000 without a problem in all volume ranges. But, everyone knows you can't hook up an anemic forty-five to sixty watt receiver or amp up to a pair of Cerwin Vega tower speakers. Unless of course you are using a receiver as a preamp to an amp that's just slightly higher in power.
But really, do you have to go into a tirade about it, I knew someone with a low watt receiver would do some complaining and you have to realize that not all receivers are rated the same. Then too your speakers are in a shorter speaker box so they should respond better to lower amounts of signal. Then since I don't know anything about what is pushing the signal to your speakers. That being the point of it all, what's pushing the signal, the crossover and the space inside the speaker box.
