The CV's were the most efficient speaker I've owned. Very very easy to drive with as little as a 25 watt tube amp to ear splitting levels. They are not power hogs in the least. Now Infinity Kappa 9's....those are power hogs!
A good friend that has CV D-9,CV Cls-215,and Kappa9's would disagree that his CV's dont like big wpc amps.
Lowest power amp he typically uses for any of those
^^^^ speakers is a 300/2 Sunfire amp,and that thing is a monster,it doubles down everytime the ohms drop,300wpc into 8ohms,600wpc into 4ohms,1200wpc into 2ohms,and that amp is stable down to 1ohm. That 300/2 is one of the few 2ch. stereo amps he's found that can reliably drive those Kappa9's. And that 300/2 Sunfire amp never runs outta steam,never gets hot,and it never clips,no matter how hard it's being driven,it's truly an amazing amp,so yeah Bob Carver probably know's WTF he's doing.
That's the same amp my friend used for his CV's,those Cls-215 are his "daily driver" speakers (that's 4x 15" woofers folks),and these Cls-215 do infact sound superb,not at all typical of the CV "party speaker" reputation. Without hesitation I'd put those Cls 215 up against just about any high-end speaker,heck they give those Kappa9's a definite run for their money,and nobody would dare to imply that those K9's are a "party speaker" simply because they're big & loud.
His other amp(s) are 500wpc Bryston mono-blocks (7B-ST),these are currently his primary amp(s).
So that Sunfire 300/2 has been relegated to doing back-up duty these days.
Could he use his 130wpc Yamaha AX-930U integrated to power his CV speakers,yeah sure he could.
Does he use that Yamaha integrated amp to drive his CV's,nope.
Why wont he use that Yamaha with the CV's ???
Beacuse the CV's just sound better with the "big" amps...
Heck he could even use his curbside find XXwpc Realistic reciever to power his CV.
Though if one even suggested doing so,I'm sure he'd laugh at them for even mentioning such folly.
Either the 300/2 -or- the Bryston mono-blocks can get crazy loud with the CV's no-doubt-about-that.
But I can personally attest that the low volume detail is really sweet with those big amps & CV speakers.
Of course YMMV....
unless you have some crazy expensive exotic speaker like halo71 mentioned infinity kappa 9's or their other model thats like 7ft tall with 32 mids & tweets!
FYI: It's not the 2 midbass couplers (1 per speaker),the 2 mids (again 1 per speaker) nor the 6 tweeters (3 per speaker) that make the Kappa9's hard to drive...
And to anyone saying high efficiency always = easy to play loud with low wpc,well FYI the rated efficiency spec for the Kappa 9 is 102db/1w/1m.
So anyone using the Kappa 9 as an example of a "difficult to drive" speaker that needs a bunch of wpc to drive vs. the CV being an "easy to drive" speaker that can be driven with low wpc amps,based solely off the given efficiency ratings of each of those speakers,well they had better rethink that logic,as it is clearly flawed.
Anyhow,in closing.
Does anyone
NEED a big amp to drive Cerwin Vega's,clearly no they dont.
Are CV's going to sound better being driven by a big 'ol amp,well that can clearly be debated ad-infinitum.
I've heard CV's being driven by all sorts of gear thru the years,and I'll take the "more wpc is better" side everytime.
I would'nt even bother to drive mine with <100wpc...
JMO
Bret P.
