Confusion on speaker stands versus floor standing
Ever sat on a wobbly 3-legged bar stool? How about a 4-legged one?
There was a discussion about this with TT feet a while ago. Of course, being AK, everyone climbed their hill and started defending.
Goes back to math ... geometry .. 3 points define a plane ..
Eucilid ..
Hills definitively require a lot more points ..
The spikes on wood flooring require little pucks to protect the floor, on tile it's about the same as on carpet over concrete.
Conceptually, directly into the wood is the best coupling .. but yeah most folks tend to use something to protect the wood.
Built rigid stands for a set of Maggies once, filled them with sand and spiked them directly in to the hardwood floors of the Victorian house that I had at the time ..
The Magnapan's sounded wonderful and you couldn't see the very small hoes that the spikes left ... but I made the spikes long and thin, and Maggie's are relatively light.
No, that's due to the name or respectively the prefix - i.e., the tri- from the Latin tres/tria for three. So a tripod has 3 legs, because otherwise it wouldn't be a tripod. :)
Greetings from Munich!
Manfred / lini
Ummm...I think he knows that.
Manfred / lini
I was referring its stability, not the reason it's called a tripod. That part is obvious.
Besides, quadpod sounds silly. ;)
Ahhh, too bad - as I was hoping for a further inquiry, so that I could have explained, that the Morgan 3Wheeler also wouldn't be the Morgan 3Wheeler, if it had four wheels. Whereas the Reliant Robin, while also a threewheeler, isn't that due to its name, but foremost for giving Jeremy Clarkson the opportunity to demonstrate, what a maldesign it is. ;)
Manfred / lini
I know there are different theories on this, but I've never quite understood the idea of spikes with rubber cups. Other than issues with uneven floors, how is that different than just rubber feet? Is there something about the cone shaped spikes that affects vibrations? My understanding was that spikes were to penetrate carpet to couple with the floor, and not "float" on top of the carpet. Or to kind of grab onto something like a wood floor to prevent sliding and ensure coupling, that imperfections in the floor and speaker base might prevent.
Spikes AND rubber cups seem like opposing ideas. Rubber would seem to decouple and absorb vibrations, whereas spikes couple? What am I missing?
Most feet come as both, mine went both ways. Spikes for carpet and wood and the included rubber feet "adapters" for other hard surfaces.
But am I at all right in the idea that rubber cups under spikes kind of negate the purpose of spikes?
:dunno:just telling you what the instructions with speaker feets I have bought said.
And it may but you still have the weight of the speaker concentrated on 4 small points with the rubber.
It would appear to me that there's no difference at all.
I think a lot of it is just fashion, received wisdom and marketing.
Speakers without spikes = non-audiophile.
Speakers with spikes = audiophile.
Thats is all I was going for ;)
That said they did help a lot in the Tiny House listening loft. that floor was like a giant guitar body, the spikes and supplied rubber feet really helped.
I would think they would function in some ways like these.
I use them with carpet spikes. So you have coupling to a floor, but with an isolation component to the implementation.
Manfred / lini
One of the funniest Top Gear episodes.
Manfred / lini
I've seen the Top Gear episode that shows exactly how easy it was to roll a Robin.
If you're going with three wheels two of them should be up front.
