direct drive turntable turns way too fast.
TrevorBarten
Well-Known Member
I have a micro seiki dd 5 that's in pretty good condition however it turns way too fast. Is there any way to fix this? included is a picture of the circuitry.ba34affa-fac4-4d28-9caa-98fd01b68f00.jpg
Same thing happened to my Technics SL-1200 MkII
KAB was able to repair it, so you may want to contact Kevin. https://www.kabusa.com/frameset.htm?/
No affiliation. Just a happy customer. He specializes in Technics, but he may be able to help you out.
I am pretty sure I just need to replace some caps but I can't find a service manual so idk which ones also I am located in the Netherlands so if I would get it fixed I'd go to a local repair shop. Thanks for the tip though!
Start with the electrolytics . Pay attention to polarity and there maybe Bipolar ones. Most will have the info written on them and if you post clear up close pictures someone will know the hard to determine ones.cheers
I would start with those orange coloured ones. I just replaced these in a Technics TT and couldn't see until20200317_160218.jpg 20200317_160114.jpg out ,appears they have oozed . The blue coloured one the one leg was green and the pcb in that spot shows signs of heat discoloring. Hope this helps. The TT still was playing fine speed dead on .:dunno:
I would start with those orange coloured ones. I just replaced these in a Technics TT and couldn't see untilView attachment 1796787 View attachment 1796788 out ,appears they have oozed . The blue coloured one the one leg was green and the pcb in that spot shows signs of heat discoloring. Hope this helps. The TT still was playing fine speed dead on .:dunno:
I don't have any caps atm so I'll need to order them first that's why I was hoping that someone would be able to tell me which ones I should replace. Should I just order new caps for every e cap on the board ?
Check all solder joints for the wires going to the motor , that is re flow the solder for them.
Might be the issue, a SL-5000 i worked on had the same issue search for runaway speed, but those are totally different motor wise etc.
Athanasios
Athanasios
I just did and that was sadly not the issue
I have no way of telling ,you have them in front of you if your not sure of a cap post a picture.
Best to take many pics anyway ,only change one at a time and verify you have good joints. Any of those Bipolar? You can put a cap in with a higher voltage rating but NOT a higher Capacitance. You should be able to get those all the same .
Could be a dirty speed control pot??
That was the problem on my Kenwood. A shot of deoxit, a few twirls of the knob and it settled right in.
