My interpretation of the massive plinth idea is that with idler tables (of any sort, manual or changer, I would guess) the motor is isolated from the top deck and the platter by rubber grommets and the idler. But that isolation is only relative, so some gets through. If what gets through has to vibrate not just the top plate, but another twenty pounds (or whatever weight) of mass, the resultant vibration is going to be way less than if it just vibrates the top plate. Just clamping down on the original base wouldn't do much since the mass of the original bases was very low, and the boxy shape would probably add a resonance to the vibration. Massive bases are an obvious solution, but not a cost effective one, shipping wise, so manufacturers wouldn't be eager to market them.
