Should I replace the white cap or the green cap?
I have http://www.digikey.com/product-search/en?keywords=399-7481-ND . Is this a direct replacement for the green cap?
I wonder if you can help me here, I had the rifa (it was actually the green capacitor) replaced but now it runs until it switches off, then the fuse blows. Would that likely be the cap in the power distribution box?Oh wow - I need to pay more attention when I read. The on/off pop has nothing to do with the transformer. In the power distribution box (where the power leads go - it is labeled KS-4) there is a .068 uF x 250 V cap across the hot lead to the table. This allows a very small amount pf current to pass through even when the table is off. Then, when turned on, the spurious "pop" is eliminated. I use a .10 uF x 400 V film cap here. A simple solder job to replace. Obviously, disconnect the table from the power source first!
