foofighter
Moonshiner
Celestion and Delta 12a.
Go active with subs and passive with Delta/Celestion combo.
I was looking into some BMS drivers as they looked quite promising....In fact, I was in talks with "Jack",one of the members of BMS to acquire some 4550 drivers and almost had a deal made "UNTIL" I mentioned that I was a member here at AK...
It appears there was a "group buy" from this website some time ago to get a discount on a bunch of drivers.Appearently there was some type of non-payment issue from one of the members and he dropped me like I had the Plague. No further response to emails,,nothing! I was a bit dissapointed because I had heard good things about BMS drivers and wanted to giv'r a go but was not to be.......If you do try to look into getting some of these ,don't mention your a member here
and you might have luck.
The Celestion tweeters doesn't have that thread to mount it on to the waveguide. How do I solve that?
Is that a bolt mounted driver? If so, you have to get a wave guide with mounting holes, or at least one you can drill and mount the driver to.
as far as what kind of box, you need to know what kind of woofer you will be using first, then figure out what kind of box would be best suited for it. Or, you could decide what kind of box you will be using, then look for the best suited woofer...
Myself, I decide on the woofer first, then try and figure out the best box for it.
Celestion 1745 has threads for 2- and 3-bolt mounting. You can use the QSC waveguide (http://www.parts-express.com/pe/showdetl.cfm?Partnumber=245-625) or try your luck with an adapter plate.
Alright.. So if I go with the above recommended horn and the Celestion 1745 I'll be on my own regarding XO?
Do you recommend me going Selenium D220Ti or B&C 250 instead? I'm a total beginner when it comes to XO and such. I've built one speaker before and that was a simple 1-way.
The QSC waveguide combined with the B&C DE250 is well documented in the Ewave thread, as the Ewave Deluxe. Highly recommended!:thmbsp:
Sticking with a proven design is the easiest route to success. IMO, the DE250 is much smoother than the D220Ti. No idea on the Celestion.
I just realized the Celestion mentioned (1745) is actually the CD used in the QSC HPR-152i speaker that the ewave deluxe waveguide is borrowed from - so it's pretty safe to say it works.
Everything about mounting Celestion on waveguide and measurements can be seen by clicking a link i posted before.
Lets try again![]()
http://www.audiokarma.org/forums/showpost.php?p=5235945&postcount=13854
You need adapter from bolt-on to srew-on. It works very well, measurements confirmes it.
Whatever midbas/tweeter combination you intend to use, you are on your own regarding xover.... unless you make one of the projects from TechTalk - Flex your PCD mettle thread.
Since you've asked only for components available in europe, i don't know where will you find QSC waveguides for it. This is why i recomended Celestion to you.
If you don't have measuring equipment, you should contact Gainphile. He did that measurements and he can tell you more of xover he uses.
