Gainphile, do you have raw measurements of Celestion CDX1-1745 on PT waveguide ?
I would like to play with it in PCD if it is ok with you![]()
Thanks alot for the input, Gainphile. Btw, your blog is superb!
So, If I go with the Celestion I can use the crossover details on your blog. But what about crossover for the woofer? You used the Beta 12 but I will be using the Deltalite 2512, so are there any changes to crossover?
It seems like a 70l box tuned to 40Hz will be good for the Deltalite 2512? Could it be made smaller?
I'm planning on crossing them over to a pair of subs at maybe 60-70Hz, so could I get away with a smaller box for the Deltalites?
I don't want to go active between the tweeter and woofers, that will be passive. But for the XO between subs and ewaves I'll go active with a minidsp.
Uhm...
So unless nobody can help me with the XO it seems like I will have to build myself a microphone like you did and do some measurements then?
But hey, if I remember correctly Zilch has written something about the Detalites... Will take a look at that after shool later today.
Uhm...
Here it is (rename it to .frd)...
You need to add 170 or so to the SPL column (because it is negative), which can be done by opening it in excel. I think you also need to have the phase unwrapped though, which would be a lot easier to do when exporting the data in the first place.G, i renamed it to .frd but it does not work. In PCD flat line appears instead frequency response. Are you sure you uploaded the right stuff ?
