empirelvr is correct-- with those DCR numbers, that particular cartridge is a clone of the 2000E/I,II,III series and takes styli with the Pfanstiehl prefix 237 [not the 237-DEZ!]. Ideally, you'd like a 237-DET (clear), but a DEC (green) would do just about as well. The problem is, of course, finding the original versions of these. I hope some folks who've had good experience with the aftermarket versions, especially the 4237-DHE line-contact one, will pitch in with good reports.
UPDATE 1: Every 2004 cartridge I've found here on AK (four or five of 'em) has come with the purple S912E stylus, not a 2000E/I,II,III stylus! So I'm looking for someone to confirm PureQuill's measurements. MUCH LATER UPDATE 2: Empire's published spec sheet for the 2004 show that it was indeed meant to be a 66-family cartridge and came equipped with the S912E. However, in the transition from the 66es to the 2000Es, factory mixups occurred, so there are many 66es that measure like-- and therefore are-- 2000Es.
