G8000 with no sound
looks clean,original and unmolested.
check components on power board...
The black wire is attached, it is just pushed up in that direction.
Pulled and out back all connections, cleaned pins that needed it, all good.
r23 reads 475 ohms
r24 reads 472 ohms
How can that be?
petehall347, am I again checking r23,24 with those boards pulled at dcv?
You definitely can not get to them put back in because they are buried behind the main Caps.
I only have managed to get to to get to the + side of one. They have this clear sheathing wrapped down the leads, pretty crazy, and it leaves no exposed lead.
It reads 0.0vdc
I will get to the other tomorrow when I can pull the board and pull the sheathing back a bit, crazy hard to get to.
Thanks for hanging in there
Ok, after figuring out better access to those Caps.
Left F-2806 the - of c11 -361.5mv
the + of c10 -351.0mv
Right F-2806 the - of c11 -365.2mv
the + of c10 -354.1mv
they should be about +- 58v
you had the voltages at pins 11 and 18 f-2814 . best check these again to be sure .
Rechecked 11, and 18 F-2814 both boards all read right around -248.0mv
Rechecked F-2806 cap voltages left and right both c-10 and c-11 now all read right at -245.0mv
I did these readings all one after the other.
I have left this powered on now for about an 2HRs or so, don't know if that made any difference.
FWIW the image of the driver board in post #126 shows it to have the same Molex connector arrangement as the F-2624 driver boards in the 8080DB/9090DB units. It is very easy to mount the board one pin off and blow power supplies/burn up ground traces if that happens.
