Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
there are also a couple threads on washing down the insides using various combinations. Read each thread thru front to back before proceeding.
After doing it once and seeing the end result AND the unit still plays makes it easier the next time.
I'd start with a dry paint brush, perhaps a hair dryer or any way to blow air. When too sticky, I use isopropyl alcohol with a brush too, and rinse with more alcohol.
A small brush with hard and short bristles is useful to scrap some places, or in between resistors and components.
I like a couple of cheap artist's brushes and a vacuum to remove the dust stirred up. It takes some time, but it is a clean and thorough process, and it lets you get up under things and in corners where air flow stagnates. It goes relatively quickly.
