Harman Kardon 330C blowing fuses
Q414 E -20.77vdc C -22.01vdc B -21.44vdc
Q416 E -20.19vdc C 22.62vdc B-19.50vdc
Q418 E 20.60vdc C 22.68vdc B-20.23
Q420 E -22.74vdc C -19.80vdc B -21.16
Q413 E 20.99vdc C -22.23vdc B 20.33vdc
Q415 E 21.93vdc C 22.93vdc B 22.55vdc
Q417 E -21.83 C 22.91vdc B 20.33vdc
Q419 E -22.93vdc C 21.15vdc B 20.33vdc
I've checked all the resistors on the whole board and they're all good. I pulled all the transistors one at a time, and they all test good. I soldered the transistors back being careful the BCE was arranged properly. I've replaced the electrolytic capacitors with nichicon caps checking the schematic to make sure they're in correctly. I re-soldered the whole board making sure all traces and solder joints were good. Still get the same results.
best get all these voltages again then .
Q413 E 21.27vdc C -22.55vdc B -20.73vdc
Q415 E 22.00vdc C 23.04vdc B 22.60vdc
Q417 E 21.33vdc C 23.13vdc B 22.11vdc
Q419 E -23.16vdc C 21.32vdc B -22.55vdc
readings probably within % of readings both posters. seems like the neg base at -22v Q-419 or reversed the reading on the test leads? the 32vdc on Q417 might hint at a resistor.
Struggling to follow this one as well - if I understand the service manual correctly (hifiengine version), most of the schematic voltages are listed on page 21.
If so, quite a few values are still wrong / not making sense to me.
Not sure if it'll help, but could you maybe check & report a new set of voltages for Q405, Q407, Q409, and Q421 as well ? A list of which transistor replacements you've used might help, even if only to eliminate possibilities.
no main amp voltages apart from b+ b- on the one i have here .
edit ... i found them in another manual i have here .. damn thing wont let me copy them ... might have to screenshot or something ...
B E C is the order of above voltages
ok as suspected both channels are wacked out .. i was led to believe left side was working fine ... something strange here .... :needpics:
Left channel was working when we started but now when I engage the speakers, ir blows the fuses. So I haven't done that for a while.
yes something has gone bad .. need to regroup ..
some pics of both sides of the board might shed some light on this .
i didn't think the voltages were correct but was being thrown by the way the circuit is with it not being the classic circuit .
we will get to the bottom of it ...
Sorry for the confusion.So I'll make an attempt at photos.
