SaSi
Seriously Illogical
After working on a B710MkII with similar problems (after solving the original ones), I re-read the entire thread. And then I had a look at the B215 Service Manual.
I now think I understand the problem, although the SM isn't good enough to help find a solution. (BTW, since the B790 and B77, Revox SM aren't the same quality on newer units).
Anyway, the problem with the 710 was that it would stop FF or REW abruptly and for no reason. This happened after I took out the boards and washed them under running water with shaving foam and a toothbrush.
The end finding was:
There are two pulse signals coming out of the reel plates. Each plate has a photo sensor that creates a frequency proportional to the rotational speed.
The CPU board on the 710 does some work on these two frequencies and then feeds the result to the CPU.
When everything is working ok, FF/REW speed is very fast at the beginning of the tape and then slows down at the end. The End of Tape sensor stops motion as soon as the leader tape is reached.
There are three trimmers on the 710MkII CPU board that adjust this. In a previous posting it was stated that there are more of these on the B215 (but the SM didn't have any details and since I don't have such a deck - sigh - I can't help locating them).
For the 710, one trimmer is used to adjust the sensitivity of each reel plate pulses and the third adjusts the leader tape detection threshold.
When the two reel plate trimmers were off, I had exactly the same problem: FF/REW stopped for no apparent reason while on tape. Adjusting the tape sensor had no effect.
A combined adjustment of the two other trimmers however solved the problem perfectly. While adjusting, I realized that the soap bath wasn't enough so I took out the board again and sprayed a generous amount of Contact clean on the trimmers. There was dirt adhered on the trimmers that soap and the toothbrush didn't remove - it just mis-adjusted them and mixed the dirt.
I'm sorry I can't give any more detailed hints here but I have no clue on the unit's schematics or PCB layout.
