What gets me in a lot of the tests of speaker cabling is that I have seen tests where they take different brands, gauge, etc., of cables, BUT they are still parallel conductors (typical "figure eight" construction), like the original Monster Cable, vs. other parallel conductor cables, and ascertain that there is little to no difference...well, DUH!
In that case you will be trying to hear the differences in insulation, metallurgy, gauge, and really, to my mind, nothing else....these are very, very subtle effects that are initially hard to discern, and many times never become an easy thing to hear...
Something like Kimber Monocle, Shunyata Phoenix, Ecosse Reference, Cardas Cross or Twinlink, DH Labs Silver Sonic T-14, DNM Reson, JPS Superconductor, even Monster M2.4 (all cables I am intimately familiar with) each sound different from each other, and, IMNSHO, miles ahead of "The Original Monster Cable", even on speakers of less than stellar resolution, like my Boston A-100's or Klipsch Hereseys, much less when using them on something like my Third Rethms or Martin Logans....
And it is "Horses for Courses"....in many middle of the road systems, expensive cabling is not called for...it's all part of Synergy...what you can afford, what you can hear, what works with your gear.
As in the previous instance of the Japanese and Scotch, there are oenophiles that can taste and discern every subtlety in a wine...me, well.....I can't, it's either too sweet or dry enough...I just never took the time to educate my sense of taste to where the different things I was tasting had a meaning, an explanation, and a reason to them....and me, well, I don't care, I like beer!
Same with training your ears in listening...and, it can really be hard, fatiguing, taxing work...yes, sometimes listening that intently can tire the 'ell out of you...but, when you are able to hear the little things that make a difference, and combine them together in your system, you can get something that sounds pretty darn good, you don't have to spend a boatload of money.
I've been lucky to have a part time job where I get to experience many, many high end audio pieces, even taking them home and using them for extended periods....well, the more you learn, the more you hear, the more you know, the easier it is to hear the little things that make a difference....it sometimes takes a lot of direct comparison to be able to hear the little differences.
Combining a lot of little improvements is sometimes all it takes to take something from dreck to delightful...
Then again, if the system is too revealing you may find, as I did, that there are a lot of things that you used to listen to that you can no longer stand....finding yourself wishing for that old Sansui or Marantz or Pioneer receiver, with it's loudness controls, bass boost, treble control, and it's murky presentation to hide the flaws that are no longer obscured...a recent listen to a Chicago factory recorded cassette tape on my Nakamichi rammed that home....sounds great in the truck...really bad in the house...but put on a Windham Hill chrome cassette and the Nak is a marvel....
I love the older gear, and it can be quite musically satisfying...but the way the new high-res gear pulls things out of the grooves on an LP or the quiet little things in the atmosphere of an SACD..well, it's darn near magical....
And as far as the Audiohorics article...well, how did they sound? Not a single word in there that they spent any real time listening and comparing the cables they were testing...hooked them up to machines and read the results...well, fine, but follow that up with listening tests on decent gear...and I'm not going to read thru 14 pages of engineers and their groupies mentally masturbating to see if they ever did listen...give me the bottom line, did they sound good or did they suck....and, could they even tell the difference?
Once upon a time I, too, worked as an engineer and can understand this mindset...but...measurements should be an adjunct to listening as a way to select things....if you like something and the measurements suggest that it's going to suck, but it doesn't, then what do the measurements even mean?
As always, YMMV, and as wacky, insane, or down right poopy-headed as these may be, they are just my opinions and experiences, nothing and nobody else's...
