Sorry, I don't mean to intrude @dr*audio. Keep up the good work.Ok guys I did the baseline, one end on R479, the other on the output jack (bottom lead on J5 on PCB9). I do hear the high pitched 12khz signal through the left channel. A modicum of progress!
I think it only puts out 400 Hz when you hold the Cal Tone switch in. There is also a Bias Tone switch which should put out 12KHz. If the Bias switch is pushed in, and it's the kind that stays in, push it so it is out, and push the Cal Tone switch, if that switch stays in. If both are momentary contact, just continue to use the 12KHz tone. As long as you can hear it, it doesn't matter.I think this HK deck puts out a 400hz tone in one channel, 12khz in the other. When I connected to the left output jack, I hear a very high frequency tone that must be the 12khz?
For the voltage readings I should have told you to set your meter on DC Volts, but it doesn't matter, it looks like Q757 is shorted.Just to be clear, the bias and tone cal switches do not stay in press pressed - must press and hold. When I get the 12 khz tone through the left output channel when jumping it to r479, I was assuming the tone came from there.
For the Q757 readings, I removed the jumper from r479 used to test c307. I then powered on the deck, set my DMM to AC Volts, 200mV range. I connected the - lead of the meter to chassis.
Not being sure which pins are ECB, I measured each at zero, wasn't sure if I needed to press the tone cal button, I did this and got 0, 0, 1.8 starting from top to bottom in the photo.
Forr resistance, I got 0, 2.1, 0 ohms readings, again with DMM - lead grounded on chassis, unit powered off.
Did I do this right? Or was I supposed to leave c307 jumped to R479?
You did not need to press the Tone Cal.Yes I do, I have replaced a couple of transistors on some of my receivers. Are you sure I did everything right taking those measurements? Did I need to press the tone cal? R479 jumper supposed to be removed?
I asked you to measure the resistance from Q757 collector to ground. (Actually I meant the emitter but you measured all 3 pins so we got the information we needed.) It should have been some larger resistance, at least 1K Ohm on the emitter but it was 0 or 2, I forget which. Either way that is too low and unless you probed the wrong lead or shorted 2 leads together, it indicates the part is bad. It's a muting transistor and it's supposed to mute the output when the deck is first turned on or off so that there isn't a pop in the output. The deck will work without it, which is why I asked you to remove it. You can check Q758 and compare. By the way, when you are looking at the transistor from the flat side, the leads are ECB. So just measure from the left hand lead, looking at the flat side, to ground. With the power off.Thank you so much for getting me this far. Unfortunately, murphy's law seems to be conspiring against me with this deck. Both sides of the main pcb board are easily accessible. But Q757 is on a smaller board facing the bottom of the chassis. The solder side is not easily accessible, has other boards stacked on top of. It has to come out, and I'm not seeing an obvious means of doing so. Can't even see how it is secured.
May I ask what reading I took that tells you Q757 is shorted? I'd be curious to take the readings on the corresponding right channel transistor to compare them.
If Q757 is definitely the culprit, I'll need to decide whether or not to risk further damage doing a complex extraction. As it stands now, the deck makes great tapes, and as much as I'd like playback, I don't want to lose what I have.
@smead, are you positive that the DMM is not displaying "OL" vs "0"? You may want to change the scale to something like 2K or 20K ohms and try again.DMM set to 200 ohms.
Ok, now that I see where you were measuring, Q757 looks ok.Yes it is not reading 0L. I set it to 20K and Q757 reads 0, .01, 2.5 measuring from top to bottom per the image I posted earlier.
Correct.Thank you for hanging with me. I have to go out of town for a couple of days for some family caregiving duties, when I get back I'll take these measurements and report back. Just to be clear, step 2) "Reconnect your jumper probe to the tone generator circuit" means one lead on R479 right? Thanks!
