dr*audio
Fish fingers and custard!
According to the schematic, the center taps of the pots are the output, so it doesn't make any sense that you should get output from the outer pins and not from one center pin, unless the pots are not wired per the schematic.Ok I had some time this morning to take these measurements.
DMM set to 200 ohms, measured outer pins on VR301 and VR302. Both right leads measure 0, both left leads measure 2.5. Those are not the ground side.
Powered unit on and connected tone cal jumper.
"Touch the jumper to each of the center pins on each section of the output control. Do you hear the tone?"
On VR 301 (left channel), no. On VR 302 (right channel), yes.
"Now touch the jumper to each of the outer pins that are NOT the ground connection on each section of the output control. Do you hear the tone when you touch each of the pins?"
Yes I do on both VR 301 and 302.
"7. Turn the unit off and disconnect the jumper.
8. Turn the unit back on.
9. Set your meter to the 20V range, DC volts.
10 Clip the black meter lead to the chassis.
11. Wrap a piece of tape around the tip of the red meter lead so that only the very tip is exposed (to prevent shorting things out) Measure the voltage on Q757 top lead in your picture. That's the base.
12. Measure the voltage on Q758 top lead."
.01 on top lead Q757. Q758 is soldered in 180 degrees backwards compared to Q757, so base must be the bottom lead. It also measured .01.
No matter, the problem seems to be a bad output control. You don't really need it so you can defeat it:
Solder a wire from the non - ground outer pin to the center pin for each section. That will make it always all the way up. You do need to leave the control turned up all the way, though.
