How to Change Out Stanton Cartridge Brush
sdw54
Can’t get there from here.
Hi All,
I see that changing a Pickering Brush is not a problem, however, how do I do the same with a Stanton Cartridge without damaging the new stylus assembly? Just being really careful... o_O
I'm fumble-fingered enough to have destroyed more than one Grado stylus when prying it from a Prestige body (not that it mattered since I only removed them when they were worn out), but removing the Stanton brush was not all problematic. I just removed the stylus assembly first, pushed the brush straight back to disengage the T-bar from the little clips inside the stylus assembly, then pulled it out through the hole. Reverse the procedure to re-install. Unlike the Grado, the Stanton stylus assembly had no tendency to twist in my grasp and damage the cantilever.
