You got it!
Dave
Dave
Same as your v7 & v8, they look pretty ideal from here, from my limited knowledge. Others may concur.Thanks so much. I had a feeling this was a problem. If I install IBAM/IBBA, what's a good target for output tube current?
34mA is a good targetThanks so much. I had a feeling this was a problem. If I install IBAM/IBBA, what's a good target for output tube current?
I'm in same boat. Haven't tackled any of my 4 projects yet (2 ea. 500c , a 400 & an x-101-d) . I need to make up a master list of all parts needed for necessary mods to all & make a mass order. I have a 1 lb. coffee can full of domestic-production 7591s, plus what's in the unit's on hand & I don't want to toast any due to shrinking supplies/ escalating replacement costs. Projects delayed due to multiple hobbies & reasons, I guess.Thanks to you both. Given current tube prices I'm inclined to go with IBAM/IBBA so now I must choose between those two mods.
As I consider the IBBA, are the values shown on Dave G's schematic OK for the KX-100 which uses 7868 tubes?
Would that rendition also be applicable to the x-101-d? I have no schematic for mine currently to ref to.Just ordered parts for my X-101-B. 99% sure drew it out right.
Outstanding! If not for being against post office rules, I'd mail you a beer, Larry. I'll research which ones to use, I might even have some in the reclaim or n.o.s. stash.Cat. Change out R74 (450Ω) and replace with zener's. Otherwise should be same.
From a "D" schematic. The manual is on Fisherconsoles. Arrow is direction of Cathodes.
Thank you Dave, I shall revisit that. Keep on keepin' on, for all you do/ have done!Cat -- If you look back at the first post, it was an X-101D that I first developed this mod on.
Dave
