Hi madtech.
I bought an old Pioneer stereo system from the local equivalent of Craigs List and the lovely old guy (just moved into a retirement home) asked me if I'd like his old speakers as well. He gave them to me gratis as the surrounds are completely rotted away.
The good thing is he still had all of the 'owners manuals' for his gear. However, for the JPW P1s there is a single sheet. Actually it reads 'PI' on the leaflet rather than P1 but they have the Vifa drivers (M21WG-09 woofer and D19TD-05 tweeter).
The leaflet gives directions on how to wire them correctly and then speaker placement and, at the end, has a small section titled 'Specification':
Frequency Range: 65Hz t0 20kHz +/- 3db at 2m on-axis
Sensitivity 98db at 1m pink noise input of 1 watt
Impedance 8 ohms nominal
Power Rating 70 watts continuous
Drive Units 200mm doped paper cone bass unit with foam surround
19mm soft plastic dome tweeter with ferro-fluid damping
Dimensions 434mm high x 254mm wide x 250mm deep
Weight 7.6kg
I hope that helps (if you're still here).
(Hmmm, just previewed my post and the careful formatting of the specs has all gone.)
