I am on to my 3rd attempt to circumvent total disassembly of the tonearm to replace the old deteriorating rubber damper on a QL-A7.
The dreaded sagging of the tailpiece had occurred. I attempted a fix using a shim at first with the original aging rubber. It lasted about 6 months before sagging returned.
2nd attempt all old rubber was removed save the tiny amount inside the bearing housing and replaced with a light weight black “foam” packing material that was easily cut to fit tightly and give support. Lasted about 6 months before the rubber inside the bearing housing collapsed. Sagging ensued to a lesser degree but was annoying. Difficult to adjust vtf when needed and sagging limits how much adjustment is available.
This third attempt is with a hard rubber bushing from local hardware store that is relatively close to needed. Slightly larger and I had to trim off about 1/16” or so of the thickness. I cut a slit vertically to the tailpiece axis to insert the dampening rubber. This has to be done in order to install it without total disassembly of the tonearm and the wires as I understand it.
I looked under the bearing housing (with great difficulty) and I cannot see a way to remove the washer from the splined shaft. I don’t see how it is attached and I don’t know how much dissembling it would take to get the tail piece apart.
I believe by placing the cut on top and the solid rubber on the bottom of the shaft it will hold as gravity will force the tailpiece into compression obviously at the bottom. No force is at the top as it will try and pull apart. Pictures are included. I regretted not taking pictures of my fine Neanderthal cutting skills used to trim down the new hard rubber bushing. I had installed it to check fit and it worked so well that I didn’t want to take it apart again for pictures of the cuts.
It looks as though this repair will last longer than 6 months. I’m estimating that it will last 2-3 years at least until the rubber deteriorated or compresses too much for proper function. It has resulted in the least amount of deflection so far and looks perpendicular even at maximum extension of the counter weight. I can improve the fix by carefully gluing the rubber back together or using a band to hold it tightly together but I don’t think it’s going to be necessary. One could also use a tie with polyester thread much like tying a fly for fly fishing. A myriad of methods or a plethora of fixes, a virtual cornucopia of methods come to mind to repair the cut that was placed in the bushing to insert it.
This was an easy fix for anyone who is willing to remove the old rubber and replace with a newer rubber bushing. If this ham fisted Neanderthal can do it, I believe anyone can.
Wish me luck with this one.
DR
