So I need a pulley and what else to change motor frequency?
Hey all. My QL-55F plays and sounds beautiful. However, the automatic start, que does not function. Once you have the album in place, press the “Start/Stop” button and it should start turning the platter, lift the tone arm, move to the play position, then lower the tone arm and start playing.I don’t have your model but mine had some issues with auto stop. Adjusting it accordingly to the manual (download online) fixed the problem. Maybe see if they have a troubleshooting section.View attachment 2761279 Hey all. My QL-55F plays and sounds beautiful. However, the automatic start, que does not function. Once you have the album in place, press the “Start/Stop” button and it should start turning the platter, lift the tone arm, move to the play position, then lower the tone arm and start playing.
My player when you push the “ready” button to wake machine up. Pressing the Start/Stop button should begin the fully automatic function. However, it only lifts the tone arm and nothing else happens. From there, I need to run the manual function by pressing the “TT-start/stop” (platter is now turning), arm operation arrow left (arm moves motorized to position to where I release at the start of the album), then momentary push the “up/down” and the tone arm gently drops into position and the beautiful music begins.
The automatic end functions perfectly at the end of the album lifting the arm, returning and resting the arm, and stopping the platter. Also while in operation, any time I push the stop/start button it lifts the arm and returns it to the rest and stops the platter.
So, everything works per design, except for the fully automatic play function. I’ve reviewed the manual and not seeing anything I’m missing. Is this repairable to a technician or just live with as a semi- automatic player.
Yes, I think I’ll take it in to Audio Specialties in Portland. Time for the big G to go in for a cleaning and calibration as well.Download the manual or bring it to a very skilled repairer, it does needs attention before it goes worst.
The main function still works but it definitely can lead to others issues later. If you see the repairer isn't very passionated about the turntable you bring or doesn't really know the brand for its high ends, walk away.
Congrats for the new tt! They're both quite different per design so maybe you'll end up keeping both! They do a lot of pull up currently as it is January and life in Japan have its costs increasing. Check them on arrival but they are normally good to go.
I’m not that comfortable opening it up. I’ll take it to my local vintage repair shop. We have a good one in Portland. You just need to be patient while he gets around to it. Thanks.Okay, I reread your post and applied some of that reading comprehension to it. I was thinking that it might be some sort of adjustment as I had in my JVC QL A7 with automatic stop but now I realize that it is not the stop but the start process failing.
I have had this exact same problem with two of my JVC LF-41 tables. Same exact issue.
I finally figured out what was going on with it. I’m not sure if it’s the same setup for you or the same switch failing but they are all JVC machines so maybe. Mine were built around 1982. Yours?
There’s a switch that activates the automatic process once you depress the start button. My arm would lift but nothing happened afterwards. The switch has contacts that will corrode somewhat and fail to connect the circuit to start the process of turning the table on and everything else that follows.
If yours is like mine, you will have to open up your table and find the switch. You can bypass it (I did that with mine) and then everything will work but the power is going to be on until you unplug it. I posted up this fix somewhere on here so you might want to do a search on it.
I have found replacement switches online that will work but I have not purchased them yet. I might just try and refurbish the old switch by cleaning the contacts. I’m happy to just use a power strip to turn on my table or a switched outlet off a receiver or amp.
How are you with opening up your table?
Edit: The switch was located near the center of my plinth where a gear could activate the switch and start the process. I had to remove the counter weight and I think maybe the tailpiece off the tonearm to get the table open. You might want to look up how to do yours. Maybe search for replacement of start switch for JVC automatic tables. Or you could try mentioning it to your repair shop that you think it might be a possibility for your issue. It could be totally different with yours however as they are different models.
Good luck with yours and let us know if you fix it!
DR
