I have heard mini monitors like the Pro Ac Response II's
http://www.stereophile.com/standloudspeakers/792proac they are a $3000 mini monitor that do have bass which have a custom 6.5in scan woofers and we are not talking your typical ordinary bass from a typical 6.5in driver there is nothing wimpy about them. I have heard a # of speakers that produce very high quality bass from small drivers. I have heard these Lorelei
http://www.odysseyaudio.com/products-lorelei.html and while I listened to them for the first time I was looking all over the room for the sub, just like people do with my Forte's. They are pretty incredible but don't have the efficiency of a Klipsch.
Glad you have found the Titanium's, I had gathered they weren't available. I have the Forte 1's and the Forte ones crossover point is higher as it uses 1.5uf caps vs the 2uf caps that the Forte II uses. The Klipsch specs say 6000hz for the Forte I while the Forte II specs say 7000hz. The tweeter comes on later for the Forte 1 due to the smaller cap size so I think the Klipsch published spec is wrong. It was one option that Bob mentioned that might be done was to shift the crossover up for the tweeter anyway. I have no issues with the Forte 1 in this regard. And in reality the tweeter network is wrong according to ALK by PWK's own admission to him. ALK talks about the issue on his website. ALK also talks about why the mid network is wrong to. But its my understanding that PWK preferred a high impedance network for lower distortion. In the end subjectively the stock network values work for me.
North Creek Inductors are very important. Iron core inductors simply compress the sound substantially. The two stock inductors changed to North Creek are a substantial improvement more than caps IMO. Though I don't take any part lightly. The Crites 6khz kit uses an iron core inductor of substantial mH size which can be costly in a North Creek air core of a large AWG. IMO using an iron core in the mid is going to do more harm then good at least with a Forte 1 so if I had a Forte II I would shift the crossover frequency up its a simpler solution IMO.
Yes the horns are damped with caulk rope.
Yes I use better caps, the Solen is used in parallel with the woofer. My amplifiers run on Solens in the final power supply stages on my amplifiers they work very well for that. I would never use a Solen in a crossover network in series with any driver but I really like DaveC's Mundorf "M" caps with North Creek so perhaps I will try them out. Although I am using a 2uF Mundorf "M" cap in parallel as a bypass to the 45 uF Solen being used to get the 47uF total that the network specifies. But if your using an iron core inductor for the Forte bass IMO your missing a lot of imformation and control more so then what the cap is doing. The stock inductor is using what appears to be 22AWG wire that is 40ft long after measuring its lenght.
Duelund now has a couple of new lines of caps that could be used. Mine are the Copper VSF 1 uF 100VDC now on sale for $141 each
http://www.partsconnexion.com/capacitor_film_duelund_vsf_speaker.html yes I use Mundorf Silver\Oil for the tweeters with the Duelund coupled to the Auto-transformer.
I use German C-Cores with 14- 1db attenuatin steps pictured here in contrast to the stock auto-transformers which are rather poor in contrast to the performance from the C-Cores including shipping cost me $250 a pair when I purchased mine but now I estimate about $300 shipped from Germany they normally come with 1.5 db steps. The 1 db steps can be had for the asking at no charge.
Here is a link but it won't last long
http://www.ebay.de/itm/ws/eBayISAPI.dll?ViewItem&item=221192790187&ssPageName=ADME:B:FSEL
E:1123
Here are the Crites in yellow contrasting the stock and from what I'm told ALK uses the same.
I believe I have heard a 604D at AKfest but can't be absolutely sure. If I did it wasn't set up like this 604H
http://www.6moons.com/audioreviews/altec/dream.html
Looks to be very interesting, I would like to hear them. But I have yet to hear anything like what these Fortes are doing with 10 watts or what jdg123's modified LaScala's are doing with 1.6 watts. I should say I have but often at the cost of tens of thousands of dollars.
The beauty of the Forte is its size and what it can do in a large or small room. Also the fact that thousands were made and can be had for as little as 5-$700 in pristine condition. I like the fact that the driver replacements can be relatively easy to acquire. Even if the Titanium mids stop being manufactured I can always purchase used Klipsch products to get them. BTW it sounds like if you have the right Altec it is quite capable of some really nice low end in the right cabinets.
What I really like to do is design amplifiers. I needed an efficient speaker so the Fortes worked good for my 10 watt SET mono's then I wanted to hear more after I heard a friends LaScala's modified with ALK networks which made them sing and thought I should try something little did I know I would create something that could stand with giants.
SET12
