SET12
So, this is correct? I am not sure of German C core wiring.
First off given a choice between the Duelund Copper VSF and The Mundorf Silver and Oils I would increase the Inductors to 10 ga or AWG and go all Mundorf "M" caps. I found in DaveC's RF25's the Tonality was a very good combination and the Mundorf "M" really did a great job with North Creek.
If you wanted to you always could later invest into the Copper VSF or the Copper Cast version.
With the C-Cores I would specify 1db steps instead of the 1.5db steps. This allows the use of the C-Cores with many other Klipsch.
The 40 ohm resistor is a Duelund 39 ohm. This is pretty much a must have as it really was significant in sweetening up the treble they are that significant vs other resistors.
Schematic for the C-Core it is in German. I don't use an L-Pad as he does. The C-Core works just like any other Auto-Transformer I get back to you more on the hook up but basically mine are 1db down for each step from the top #15 is in and #0 is ground #9 is 9db down for the Forte. If you get the standard winding it would be #6 for the 9db down.
SET12
