jc,
Here's a real Rube delight! It's for the K510 horn and uses 2 constant ZO equalizers and two transformers. Three resistors are NOT actually there. The one marked 1e+06 at branch number (on the left) 5 is open circuit. The other two are 0 Ohms at branch numbers 10 and 18. I forgot to round of the cap at branch 16. It should be .92 Uf if you can get that value. 1.0 Will do.
The response is +-5dB up to 20 Khz. Impedance match is 1.5:1, which is Ok.
AL K.
AL K.
