Here's a WAG!
Hi Cheon57,
Its not a preamp, tranceiver, or amplifier, its not a parametric EQ, it's not Marantz, Phase Linear, etc.
But it is short and wide, has a lot of controls on the front panel, and has relatively early phenolic style boards with mostly discrete components and a signal bus with plug in connectors.
From my research, it is a type of Equalizer device! It is something that works at multiple frequencies and at high frequencies - the right most circuit boards with the IF type can transformers and a very early version of an inline integrated circuit, simplifying a very complex set of circuitry.
And it was the forerunner of something pretty much all of us have heard of, used, and may even have in our homes right now, although in a very modern, simplified and automated sense (literally switch in, and switch out). It gave rise to a number of variations, most of which were successful.
Also, you were given hints all along while sanding those KLH Speakers!
Just "B" very certain during this Advent season that you have at least 100 reasons to check out the latest Santa Kloss movie in that Dolby equipped movie theatre, otherwise the reduction of noise will be to no avail!
Regards,
Bart
