wbain
I saw the idea using the threaded rod here and what a brilliant idea it is. Here is my version that I build for my ham shack this past weekend.
Nice rig.
73 warren
That's a very clever design, but if you want to make it not so darn heavy, and use less wood, consider using thinner sheet goods with internal bracing... essentially a hollow frame with a thin "skin" and thin cross pieces internally, like a guitar or an airplane wing.
Heavy is a good thing for me, but, if using ¾" baltic birch ply, I estimate it would cost me ~150$ of wood alone. MDF might be a cheaper option. I see the finish as either painted to fit a specific room or veneered, so all will be covered up anyway. I would go for painted were I to do it.
Hope the joints are structurally sound as I sketched them, I'm no expert in this area, but it seemed good this way. Glued and screwed naturally.
In my mind I'm picturing the top shelf sagging under it's own weight. Since only the edges of the center layer in any panel are exposed, you could cut out large 'holes' in the areas that are sandwiched between the inner and outer panels, or, to save on material, use just narrow 'planks' of the same material along the edges.
Unless it's going to show as part of the design, consider staggering those joints where there are 2 or 3 ends that are the same length ending perpendicular to another panel, ie, cut the middle layer 1 thickness shorter and extend the mating middle panel 1 thickness longer... do the same with the 3rd layer... sort of like a stairway. The steps will interlock and add some rigidity to the joint and will keep it from racking if there is no back.
Just some things to consider...:scratch2:
I made this a few years ago. Adjustable shelves, all solid curly maple. Rather heavy duty.
Have any detailed photos of that?
Also, what did you use for the various finishes?
I made it with stout mortise and tenon joinery.
It kinda shows!I rarely use plans since I have been building furniture for a spell now, just need a good visual.![]()
You can use a mortising machine to cut the mortises and a table saw to cut the tenons. You can also do it all by hand with drill, chisels, and saws, too.I had to look it up... :shame:
Did you machine or with hand tools it, which machines/tools are used to get this result?
This is a very elegant way of building cabinets...
It kinda shows!![]()
