Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Finally, after much patience and searching I've gotten a pair of Polk Monitor 7b's with peerless tweeters and the little hole poked in the center to replace my 7c (with the sl-2000). No real point to this post except to share.
Thanks guys! For whatever reason i just could not get my hands on the one's with the Peerless, and then to get the ones with the little hole poke is just a bonus for me.
I do prefer the 7b I think. It's always hard for me to tell the difference in short listening spurts. Typically what I do is listen for 2-3 weeks to one, and then go back to the old one and see if I feel like anything is missing.
Having said that, my initial impression is that it's a little more gentle at the top of the spectrum (in fairness could be some placebo because that's what I read that it should be...but I think that's what I hear). I'll let you know definitively in a couple of weeks.
I recently bought some KEF Q35's to compare with and I definitely prefered the Monitor 7c's. I also have some AR93s that I used for a bit, but when I hooked the Monitor 7c's back up after my couple of week listening period, they stood out immediately as more clear to me.
I'm using an NAD 1700 monitor series pre and an HK 870 main amp. Turntable is a Rega RP1 (I also have a Kenwood kd 5070 I periodically put in rotation). And for a DAC I'm using the Allo Boss 2 Pi DAC hat.
I think it's decent in the mid-fi region. There's obviously a lot better out there but I haven't been into this that long.
They were sounding a little muffled to me, popped open the crossover and the caps were swollen. Just replaced them with Dayton's and they sound much better now.
I don't think I've ever run into swollen caps in a crossover. Out of spec, yes.
That's a new one for me. I used Audyn and Dayton's in my Monitor 10's. A couple of the old caps were out of spec along with the poly switches and even a resistor.
Well, I'm a beginner so I could be misinterpreting what I'm seeing also. Here's a pic of them. The red ones appear to be bowed out at the ends. I did buy resistors to replace the existing ones but I ended up leaving them. Primarily because the vendor only had one of each and the others were on backorder. Guess I'll replace them when I get the balance.
