onkyo m-506r light issue.
CaseyWKC
Somebody was in here before me. I think?
What is the correct wiring for the M-506R? Only one set of lights seems to be wanting the work when the relay kicks on.
Thanks so much.
I can't find another instances where these traces are cut up this way on the board.
The outer meters work okay but both middle lights won't light up once the relay engages, the old lights, the ones that were good worked just fine.
They are the appropriately modified LED replacements for this unit, I know polarity isn't the issue.
Should repair these cut traces in the hopes that this is my issue?
solved. Was just the traces.
One of the lights died and previous owner or tech must have thought one light was bright enough so he used the traces to jump one and still have the other turn on.
