Poultrygeist
Lunatic Member
Speaking of small baffles here's the Linkwitz Orion. Woofers in M-frames.
Still planning...
When mounting a LF driver and a wideband driver to the same baffle in an open baffle set-up, is it important that the wideband driver be spaced back some (into the baffle) to put the voice coils of the wideband and LF drivers in alignment with each other? I heard something about this keeping them in phase.
I also read that the drivers should not be centered on the baffle. Does this specifically apply to wideband drivers or does this also apply to LF drivers?
My questions stem from watching this video.My understanding of having the voice coils in line deals with time alignment, Supposedly the resulting sound from each driver will exit the drivers and be more coherent. Personally in MANY DIY speakers both Open Baffle and Horns I have never found this to be a real issue in SOUND. I know it can be shown in measurements (I dont listen to those)
More or less the same issue with mounting the drivers off center this is supposed to be so the soundwave reaches the ends of thee baffle at different times improving detraction & ? Oddly enough I mount all my drivers in the center, If you look at a square with a circle in the center there are literally dozens of different measurements I could take from my driver to the edge of the baffle it all depends on where I want to place my tape measure.
I tried the off center mounting and could not hear any improvement with off center mounting. I am positive someone could take a measurement and explain why its better. I am not positive most people could actually hear the difference.
At some point you will need to simply try an OB speaker and decide for your self if it is worth the effort. I understand the research, None of that will actually tell you if you will enjoy it. I have seen people like Nelson Pass build and LOVE Open Baffles, SLOB's + others and I have seen his drivers mounted center and with his SLOB its is impossible to align the voice coils.
I cant decide wether or not to take him seriously. On one hand he seems to know what he is talking about, but since he is a manufacturer making money off of his designs that tells me he has an agenda beyond educating the public. Good video either way though. What do you think?
I've never listened to any of his videos.
We have a pair of his Superminis also. When the wifes out for more than a day I move all that stuff between the speakers to another room.
Got pictures of the superminis? Do they use the same drivers?View attachment 2429137
It depends on the frequencies in question. At 5kHz the wavelength is about 2.6 inches, so an offset between drivers of about an inch is a significant proportion of the wavelength at 5kHz.When mounting a LF driver and a wideband driver to the same baffle in an open baffle set-up, is it important that the wideband driver be spaced back some (into the baffle) to put the voice coils of the wideband and LF drivers in alignment with each other?
Super Minis use planers.Got pictures of the superminis? Do they use the same drivers?
Would it be fair to say that there is nothing to loose and everything to gain by offsetting drivers?I like Danny, I am sure he can show improved measurements. But think about that for a minute
You have a computer with a calibrated mic taking a measurement of X, Of course it will pick up things the Human EAR cannot, Further All Ears hear differently. Also consider the speaker you posted a pic of the PAP every driver they use is centered on their baffles and every driver is at a varying depth as the baffles are curved. I happen to know they do not use any DSP etc... correcting for time delay defraction etc... Now consider the hundreds of positive reviews from there owners. Think about Spatial, and Emerald Physics both center there drivers and neither use DSP in there passive crossovers All 3 have several audio awards with a LOT of positive reviews and even more satisfied owners. OB speakers are not for everyone some folks simply can not get past the BOX Thats fine, their perception of what they hear is what appeals to them.
The question is not can a measurement show improvement, The question is can YOU HEAR IT, will it make an actual perceived difference in what you are hearing.
You will not know if you LIKE OB till you actually try them, all the research and views of folks on the net including me means NOTHING. You simply must try them. That will answer all your questions and I dare say it will do that in mere minutes. It did for me
One day I want to build Danny's (GR Research) X-Static OB speakers, But currently I think my Spatial X-2 Clones are about the best speaker I have heard / owned. I have no real desire to stray, though I am always looking
Furthermore would it be fair to say that these things that can be measured but cant be heard are the things that separate a good system from a great system?
No.Would it be fair to say that there is nothing to loose and everything to gain by offsetting drivers?
Do tell.No.
And no.
Sorry, I misunderstood. I thought you were talking about setting one driver back from the other for "time alignment".Do tell.
Lets say I offset a full range driver on a 36in wide baffle all the way to one side leaving a couple inches of exposed baffle to one side of the driver and about 25in of baffle to the other side of the driver.
What would this do to the response?
