Even with that big of size, this will give you a chance to get a taste of OB. Good for you!!
I found a larger baffle size like that to have a bit too much of a room divider effect and I didn't really care for it. I've since not gone much about about 24" or so in width and made it taller. I like what that does better.
Not completely sure if you can get drivers that low of q to give you the right bass for OB. But again, it should give you a good idea of the sound of OB even if you can't get the deeper bass. You will have to eq those enough that power demand will go up and movement will be greater than a more proper driver. Every bit of greater cone movement is greater distortion. Though it may work ok...no real rules.
In TB 8" drivers for full range use, run in a stack of either 3 or 4, I found that they do ok down to about 75-125hz. I've played with crossover frequencies there and typically run about 80hz since I went to four. More drivers gets lower. You need cone area for lower frequencies and in OB for sure you do. That single 5" for the full range part I think I'd look for a crossover around 400 or so. With an electronic crossover, you could try 250 to about 500 and see how the 5" versus the woofs sounds.
And hopefully you're aware you'll probably want to wire the set of four drivers series/parallel so that you get a decent amp load. If they're 8 ohm, you'll get an amp load of 8 in series/parallel.
Make sure you play around with lots of space behind...more is better and hear what that does for the sound. And enjoy!
EV3
