Open Baffle Epiphany!
What does each color signify?
My guess is the orange for the woofer and the green for the mid/high drivers with the purple being a combo of the two
but how he got such a linear response from 20hz to 20kHz with no roll off is beyond me.
One woofer directly in front of another? Interesting...
So, one thing I am trying to wrap my head around at the moment is the different types of baffles used.
Looking around, I see the following commonly used. There are others, but these are the common ones.
1 -- H frame
2 -- U frame
3 -- Flat baffle with no frame or wrap-around
I am having difficulty understanding how to choose.
I was planning on #3 because that is what most people seem to use looking around on the net and it looks the simplest to DIY.
Since you have a D220Ti in your forum picture you could use them in this build. The Beta 12LTA is not expensive and would also work great in flat baffles.
https://speakerprojects.wordpress.com/2016/08/29/eminence-beta-12lta-on-open-baffle/
I decided to finally join the club with a pair of Wild Burro Betsy’s. For now they’re just in solid aspen boards that I had left over from a different project. They roughly approximate Caintuck Audio’s design, albeit without the curved baffles. Mine are angled back such that the centers of the drivers are aimed at about ear level (seated) from a distance of 10 feet.
My initial impressions are that they sound very nice. I wish they had a little more on the bottom end, but I probably shouldn’t expect that much from an 8” driver in an open baffle. However, they are capable of playing low if you’re willing to use tone controls.
I’ll probably leave them as is and enjoy. Any tips on how to stain aspen?
Those look nice. For staining I would condition the wood first so the stain doesn't go all blotchy. Use whatever stain you like after. You can buy the conditioner same place as the stain.
Pgeist
What is the Inductor in the pic with the Betsy ? I have been considering going passive on my Bass, approx where does it cut the Bass ? would you happen to have a link ?
Thanks Joe
Looks to me like the inductor is on the woofer not the Betsy.
I think that Poultrygeist uses bi-amping for his OB's if I'm remembering correctly, but I'm not sure if that's the case here.
Yes I understand it is on the woofer, Effectively creating a LOW Pass Filter. I am curious as to its value and what effec. Freq it is cutting off at
Thanks Joe
Thanks Joe
Gotcha. I was a little confused for a bit.
When you said "approx where does it cut the Bass" you meant the bass speaker not the bass frequencies.:thumbsup:
I thought about this, but there are 2 things I am intent on for the moment.
1) Not using a passive crossover
2) Keeping the entire thing dipole
The compression driver would require a semi-complex network and is not dipole so for the moment, this idea sits on the back burner.
A single cap on the tweeter is not much of a crossover. It's really just a bass blocker.
Open back tweeters are rare. If you pad that highly sensitive compression driver down enough you might find it works well. There's always the option of firing the compression driver to the rear. Danny Rich favors that approach.
I see this a lot and it does not make sense to me that the 2 drivers are so far apart. Isnt it ideal to keep the drivers center to center distance to a minimum?
OB woofers need to be close to the floor. If mounted too high you'll lose bass output. The full range drivers ideally should be near ear level or tilted so they're aimed at your ears.
There are a number of ways to add a little extra bass inexpensively.
Woofers below the Betsy, a single or pair of woofers on their own flat baffles, or a single 10 or 12 in an H frame (very compact at @1 cu ft), all with a plate amp (or 2 amps for stereo with 2 helper woofers). If you use a single driver with dual voice coils you can use only one coil with a plate amp, doing this doubles the driver's qts for more bass.​
In a earlier system I had a pair of Alphas hidden behind two cabinet doors. When I fired them up I'd pull them out into the room. No problem mixing OB bass with monkey coffins. I drove them with a class D JVC AVR.
