Open Baffle Epiphany!
I'm building baffles for the F-15 but having trouble reading the tiny specs at Lii Audio ( my eyesight isn't the best ).
Can someone provide me with the hole size for the F-15 driver. Thanks.
This is the email I just received from Lii Audio. What do you all think? I'll be front mounting.
Dear Paul,
"The outer cutout is 39 cm and inner cutout we would suggest 34 cm, for the outer better leave extra 1-2 mm to facilitate the installation.
Best regards,"
I just ordered a pair of Lii Audio F-15 drivers ( currently on sale ) and will build my own rectangular baffles rather than copying this Caintuck barrel design. Lii Audio informed me that their US warehouse is out of stock but I can expect delivery within three to four weeks. They're also sending a pair of F-6 drivers to make up for the delay. Nice gesture on their part.
I'm anxious to see how the F15's compare to the Zenith Alnico wide band drivers.
Hi Poultry,
I hope that your new F-15's turn out to be better than you ever dreamed!
I have hung my hat on my old GE alnico's? and my TangBands, and have stopped
looking for anything else, but I couldn't be happier.
The search is always exciting though :)
Hi Poultry,
Thanks. Interesting enough I've read that the F-15's remind folks of the big vintage alnico's.
Hi Poultry:)
How are your baffles coming along?
Almost done but the F-15's haven't shipped yet. :mad: Lii Audio has a warehouse in California so once in the US the F-15's should ship from there. I decided to go a bit larger than some of the baffles I've seen at 30" wide by 36" high. I already have a smaller pair of baffles used with a set of Eminence Alpha 15a's so I can compare the two. I'm using 3/4 MDF as I had a sheet in storage. But I prefer 3/4 MDF over plywood as it's denser and less resonant. I'm covering the MDF with heavy textured wall paper which I'll probably paint. I'll post some pictures once I complete the build.
When I returned the F-12's that I had, I sent them to California. It will be interesting to hear how they work out for you. The F-6's will be a secondary adventure. Nice if Lii to sweeten
the deal with them, but it doesn't help the waiting!
Awaiting the F-15's. They're 31"w x 36"h made of 3/4" MDF covered with thick painted wall paper. The tilt angle adjustable feet aren't shown. These brutes are really heavy probably twice as heavy as 3/4 plywood and far more dense with less resonance. You'd have to play at really high SPL's to excite 3/4" MDF baffles.
Those look good and solid Poultry! You think they are heavy now, wait till you get your F-15's mounted:)!
I am really looking forward to hearing how they sound. Hope that they roll in for you real soon:banana:!!!
Wow! Those are beautiful. Clean and simple.
I like the handles to help move them around.
Think I found my next project.
How did you paint the wall paper? Spray paint?
Thank I found my next project.
I first applied a coat of primer to the baffles with a brush and then glued the off white wallpaper to the baffles. Used a brush with a sample jar of Home Depot Behr Ultra in Silver Hill ( flat ) to paint the wallpapered baffles. The L brackets and handles are from Lowes.
Wallpaper adheres well to MDF if the MDF is first primed.
My wife there was a fire last night hate to have to tell you...Those look like fun would be cool to have a listen almost think a larger fullrange in the middle might work better interested in your thoughts on these baad boys.
There may be some advantages to a larger full range.
But I have the adjustable crossover point rather high. The woofers I am using play CLEAN up to 1000hz. And the full range I am using does very well down to that frequency yet is crystal clear into the very high frequencies. A bigger full range may not be as clean into the highs, or would it? Don’t have one to try.
