Personally, I don't think that's feasible. The weight of a driver makes compliant mounting impractical in my opinion.I seek driver to baffle isolation. It doesn’t have to be perfect.
Since a flat board is unsupported at its edges, that's where a lot of movement occurs. Adding reinforcement at the edges, similar to what the SFB baffles have, would be an effective way to suppress unwanted movement.
How did that sound compared to a more conventional baffle mounting? It is hard for me to imagine how high of SPL's would
Here is an idea…
Currently full range and LF drivers are on the same baffle, as such the frames of all the drivers are coupled together.
The goal is to decouple the drivers so that the LF drivers are not rattling the full range drivers and do so without changing the physical location of any drivers.
What if I removed the LF drivers and put them on their own baffle. Then I located the new baffle in front of the original baffle (which still has the full ranger drivers), utilizing the original speaker cutouts, and maintaining a 1/4in gap between the new baffle and the original. This keeps LF driver to full range driver distance the same while eliminating driver to driver interaction. The new baffle would have its own structural support and would not be touching the original. This would also pull the LF drivers away from the original baffle a bit, which is good as that would put the voice coils of the LF drivers and full range drivers into alignment.
What do you think ?
That sounds like it would decouple the LF baffle perfectly! Also time aligning the speakers would never hurt. I say it is time to put down the coffee cupHere is an idea…
What do you think ?
!!!Here they are set up.
The woofer in question would qualify as "true OB" then because the QTS = 1.1If using a true OB bass woofer there shouldn't be any rattling of the baffle. OB bass woofers have loose cones/suspension with high Qts ( .7 at a minimum but higher is better ) so they can move more air in free space. A low Qts woofer with tight cone/suspension needs a box and depends on the air in the box to function like a spring.
^ That isn't an OB, it's an NB.![]()
And to be clear, the full range drivers are getting "vibrated". As in, remove power from the full range driver, keep power to the woofer, turn up volume a little, place your finger tips on the cone of the full range driver. In this case the cones are moving a decent amount and I seek to eliminate this as I am convinced that as is they do not sound as good as they would of the woofer was decoupled mechanically. Distortion has to be on the up and up as long as the woofer is vibrating them.
Not sure if this might be the cause but just some food for thought: did you short out the full range drivers when you disconnected them? The air pressure alone from the other speakers can cause a passive cone to vibrate. A simple wire between the two terminals of the fully disconnected full range is all it takes.The woofer in question would qualify as "true OB" then because the QTS = 1.1
I did not short them out. I’ll try that next time I have them up and running.Not sure if this might be the cause but just some food for thought: did you short out the full range drivers when you disconnected them? The air pressure alone from the other speakers can cause a passive cone to vibrate. A simple wire between the two terminals of the fully disconnected full range is all it takes.
