Doesn't the 1808 have a rising response in the upper midrange?
Maybe a more balanced driver like the Heil covers that area where the 1808 gets a little hot?
Good thinking. But now I'm a little confused as to whether I'm posting in an OB thread or a single driver forum.
This might be a goofy question, BUT since my brain is bored and working overtime, just out of curiosity: I've seen many OB designs that use a panel with fold-back wings.
Would there be any advantage, or more so, disadvantage to adding wings in the front along with the ones in the back? Would it hinder the sound in any way?
I have only seen one builder do this and he didn't get into much detail...Thanks!
here's a top view sketch of what I'm talking about (cross fingers, hope it loads)
@PG - Of your various builds, which do you feel offers the greatest sonic advantages? The single OB with the drivers mounted vertically? The H-frames for the subs with smaller OB's on top for the FR? The folding screen?
It's hard to say. I really enjoyed the TB and Beta12LTA over H-Frames but then went with the DX3 with dual Alphas on a flat baffle. I need to try the DX3's over H-frames to form a better opinion. Dual H-frames ala MJK may be the best yet if you've got the real-estate.
The folding wings are too massive and difficult to move out into the room when you want to play them and like any other OB they require bass augmentation.
Besides SEPPO's explanation, which applies to wings, but not necessarily a folded OB, in OB you need a front baffle of certain size, sometimes the width of the baffle is too much, so folding them (wings) gives you the baffle width needed (front + sides) without the extra footprint. If I'm mistaken, someone else here can elaborate.
Been reading up on Open Baffle design theory trying to see if there is some kind of ratio between driver size and baffle width. Also if there are different baffle width considerations for subs and FR drivers.
Thought larger baffle gives you bigger bass.
Sent from my X10a using Tapatalk 2
Not an expert by any chance, as you guys I'm learning as I go along, also read a lot on the subject. I don't think there is a ratio, as each driver has different design parameters (Thiele-Small), using those parameters is that one can determine how the baffle size will affect the sound. Personally, I use The Edge software to see how will the driver react, not only the driver brand/model affects the design, but also the baffle size and location in the baffle. I'm playing right now with position and size of an OB for a 4" Mark Audio CHR70.3 full range driver. There is a 3.2Hz bump at around 12KHz, with adding couple of inches and moving the driver eccentrically to one side I was able to tame that bump to no more than a 2.7Hz rise, I could do it also electrically, but rather do it mechanically. Again, learning and understanding as I go along.
