Have you actually tried this? Meaning the shrink wrap. The gluing part is fairly obvious.Hmmmm...
I thought you would simply put some thermo-shrinking tube on the cylinder part of the worm gear, - glueing its' fractures first.
,A tight fitting spring? but tough to get on after gear is glued.Well... I did not try to fix a part like your's but I can judge by the tightness of cables I cover with thermo-shrincable tubes. The pressure is very significant.
In your case - the main strength would come from the glue, the tube will "help" to tighten the joint, also - the more evenly spread pressure helps to prevent new fractures from appearing. Just select a tube with an initial diameter (before shrinking) closest to the diameter of that cylinder end. Also - there are such tubes with a glue layer inside.
If you insist on that "wire bondage" - I'd took thinner wire and made several windings along the cylinder part before tightening....
,You must not have seen an original sleeve or read my earlier post.More than two rings - is an overkill in my opinion. If it is tight in two - let it sit that way. The more rings - the more motor vibrations will reach the TT frame.
,OK. So I thought that your idea of using the shrink wrap might be worth trying.Hmmmm...
,I think the white plastic bits are acytal delrin, which shrinks as it ages and basically unglueable.I have been watching this thread with interest. I no longer have my PL-L1000. The aging parts finally frustrated me beyond keeping it, but parts from it have kept several others operating and I’m happy for that.
With regard to the the white nylon worm gear (and all the other white nylon parts) they don’t age well. They become brittle and crack, split or break. I know of nothing that can be done for that situation. Internal vice. I believe they can stand being washed in acetone to remove the oil and/or grease. After that you may be successful using one of they cyanoacrylate adhesives formulated for plastics. If you are committed to keeping this turntable operating long term, I suggest you buy a decent 3-D printer and learn to “print” replacement parts.![]()
