Doing well guys I was gonna say what's the point, can't get good cheese anyway.
This is what i use for 90 second grill pies. Dough recipe at bottom, included the rest in case anyone is interested.
I've been up and down and around the block on grilling pizzas. I've tried propane, charcoal, big green egg, and just about every gizmo on the block.
I'm going to preface this post with the fact that I can't get enough Neapolitan style pizza and there are very few places in Ohio that do it well. The last good one I had was at Bono To Go, tucked away between Grandview and UA in the side of a convenience store...I'll also say the right way to make these is in a properly-designed wood fired oven, but below is how you achieve similar oven conditions on a grill.
1) Start with a Weber 18.5" kettle grill (you can go bigger if you want...)
2) Cut a 11" diameter hole out of the bottom.
3) Place some ceramic briquettes on top of the bottom shelf in the grill.
4) Place a 17" kiln shelf pressed pressed against the front of the grill on the top shelf.
5) Bolt the ash catcher in an inverted position on the interior of the lid. You will need to drill a few holes.
6) Cut a slot about 1.5x10 inches in the lid (see picture).
7) Place the main grill on a 150k BTU propane burner.
8) Fire that thing up and let it heat for about 20 minutes.
9) Using an IR thermometer measure the temperature of the stone. When it reads 725-750 F you are good to go.
10) In the meantime you will have need to have made your dough and have it ready to go. My current recipe is:
700 g Caputo 00 Flour
300 g Giustos AP Flour
640 g filtered water
50 g San Luis Obispo Sourdough starter
15 g sea salt
I mix roughly, rest 20 minutes, mix again for about 10 minutes by hand, windowpane test, rest 3 hours at room temp, divide and ball, cold ferment for 2-3 days and pull 2 hours prior to use and leave at room temp. 7 oz dough balls make 10" pies.
View attachment 1001593 View attachment 1001596
I was tempted to get a pizza kit for the kettle. (It is essentially an insert with a slot in the side of it, and other accessories.) I may do that next year after I upgrade the kettle (going to get a Performer Deluxe). Not quite the Neapolitan method but for us it will be plenty close enough, and we don't have pizza all that often.![]()
I ate at the airport Varasanos and was impressed. I'm a big fan of Anticos as well.Jeff Varazano became famous in the mid 2000's for his website that thoroughly details how to produce legit Naples style pizza at home... he now has a successful chain of artisan pizzerias in the Atlanta area
http://www.varasanos.com/pizzarecipe.htm
View attachment 963423 View attachment 963424
Ouch! I will still have my old kettle around (useful for parties), so it might be better to use that one if I mess around with a kit.Watch the plastic lid rollers. The Pizzakettle with the baking steel gets hot enough to melt them.
Good plan for sure. I'm thinking of getting an 18" to modify as above.Ouch! I will still have my old kettle around (useful for parties), so it might be better to use that one if I mess around with a kit.
I couldn't cut up a Weber (unless it were an older used model). But I'd have no problem doing that with one of the cheap off brand grills.Good plan for sure. I'm thinking of getting an 18" to modify as above.
There's a few places around here that go by the name of 'Just Pizza' that sell dough to go, and their pizza is awesomeNever tried it, but a friend says many pizza places will also sell you dough to go.
Man, that looks so good I could literally smell the pizza when I looked at the pics!..and no, I'm not exaggerating eitherHere is a nice writeup with pics I found on the web.
http://www.bbq-brethren.com/forum/showthread.php?t=144075
Our local market has their own pizza dough, plus I am pretty sure our local pizza place sells it as well. He sells the pizza pans that he makes the pizzas in (kind of a Detroit tradition--the original Detroit-style pizza, a la Buddy's Rendezvous, was baked in the same type of metal parts bins that were used at the auto factories back in the mid-century).Never tried it, but a friend says many pizza places will also sell you dough to go.
OooohhhhKaaaayyyy just remember you asked for this,LOL.
My Pizza dough:
3 to 3 1/2 cups high gluten flour (12% protein or higher)
3/4 to 1 cup water (warm)
1 tbsp. oil (olive oil or vegetable oil)
1 1/4 to 1 1/2 tsp. active dry yeast
1 1/4 to 1 1/2 tsp. sugar
1 tsp. salt
Bret P.
