If I where you...I'd get one of the discontinued Music Hall tables..the 2.2 which is discounted because of the new model. Then you can upgrade the cart. And it comes with a dust cover. Or you can get the new model which retails for $499. it comes with a better arm.
Music Hall MMF-2.3 Turntable
Plug-and-Play Simplicity, Easy Operation, Excellent Sound: Music Hall MMF-2.3 Turntable Includes Preinstalled Cartridge, Pre-Mounted Carbon-Fiber Tonearm, and DC Motor
Part of an improved line that better meets the demands of vinyl enthusiasts and exposes the unique joys of spinning LPs, the budget-priced
Music Hall MMF-2.3 turntable is plug-and-play nirvana. This two-speed belt-driven ‘table comes equipped with a preinstalled
Music Hall Spirit MM cartridge (a $100 value specially built by the experts at
Audio Technica), an upgraded and pre-mounted carbon-fiber tonearm, and separately isolated DC synchronous motor. Everything about
MMF-2.3 – from the rock-solid construction to the high-grade parts – focuses on the critical components responsible for playing music with involving dynamics, absorbing detail, and sought-after analog warmth. Such worry-free simplicity means you'll be placing a record on the ‘table and hearing excellent sound within minutes of unpacking
MMF-2.3.
Everything About MMF-2.3 Is Chosen for Performance
Not that MMF-2.3 overlooks anything essential for engaging listening. A full-size alloy platter and felt mat help provide requisite speed stability. The high-precision, stainless-steel and bronze bearing assembly delivers quiet, fluid operation. The tonearm supplies great tracking of your LP grooves, and adjustable vibration-damping feet cancel out footfalls. You even get a dust cover and 45RPM adaptor so you can easily spin both 33RPM and 45RPM records. MMF.2-3 also looks snazzy, with several available high-gloss finishes. Add in the
Music Direct 60-Day Satisfaction Guarantee, and MMF-2.3 basically sells itself.
