Q-up tonearm lifter
sarpilot
Member
Has anyone out there used the Q-up tonearm lifter on a Music Hall mmf2.2 turntable? In particular if there’s enough room between the tone arm base and platter for proper installation.
I have a spare that worked on a U-Turn I had for a family member. I've seen the Music Hall, And should work fine. You can test in different areas before permanent mounting.
They generally work on any flat decked, straight sided platter tables. They generally don't fit well on sloped platters or flying saucers like Denon.
