Agreed, too many variables in listening to clips of someone else’s system.
I’ve used a weight for years on my modded Thorens, I wouldn’t be with out it now, however I did find the differences to be far more subtle than yours.
As to Linn not recommending a weight, I can understand their not wanting 2+ pounds on the bearing. This is a hockey puck, weighing in at 5.5 - 6 ounces (less the mass I removed with the drill). I plan to take another puck (bought a 3-pack for $5.99) to a local woodworking shop, and ask them to throw it on a lathe. Then I can make sure the hole is centered, perhaps take off the texture and the "made in slovakia" imprint from the sides, and maybe even drill out some lightening holes to ensure maximum longevity in the bearing.
I (rarely, as it really needs to be wall mounted to eliminated football vibration effects) use a restored HK T60, which has a belt drive, tuned 3 point suspension designed (must use) for the weight that came with the TT. I agree it does seem platter mat and suspension dependent. The T60 uses a rock hard sound deadening mat, with virtually no grip on the record. When I use the clamp on my YP-D8, with various mats, I notice no discernible difference while on the T60 it is very apparent.
here's the pickering red button clamp on my 3 point suspended for those interested trying one. They do look good when spinning !![]()
that kind of defeats the disc from contacting the platter surface, allowing for vinyl resonances to get to the cartridge.
Instead of a weight or a clamp try this: http://www.trans-fi.com/resomat.htm
My TT is designed to work with the clamp that came with it. I have a Reso Mat and like it better. I know, goes against traditional thought, but so have a lot of other successful ventures.
About how much would one of those set you back? How do moderately warped records play on it? It seems like they would have a fair chance of slipping on those cones.
Please describe what vinyl resonance your talking about?
Marc mc
