Take a look here
On the records, the speed can even reach 40–41.2 cm per second. So what do we see? The friction force arises when the plate moves, as a result of the needle catching on the grooves' irregularities. The needle pulls on the tonearm, causing the float on the water to tilt, which in turn moves the string with the 5 g weight. The weight is also in a glass of water to prevent unwanted vibrations. The greater the friction force on the needle, the more the string with the weight deviates relative to the suspension. For the vertical setup, the head used is an average Corvette 008 with an elliptical needle. The weight on the needle is set to 1.5 grams according to the instructions for the head. When the groove is silent, meaning without a signal, the small weight deflects by 5 cm, which corresponds to a friction force of 0.5 g. So, the coefficient of friction for a silent groove is close to 0.3. When the needle hits a groove with a signal, different frequencies create different deflections, with the maximum deflection...
2:38 deviation, maximum deviation 8 2:42 so it turns out that the added friction force 2:46 when the needle hits 2:49 modulated 50% of the value for silent 2:52 groove, and this measured addition, by 2:55 analogy, through conjugation 2:58 by computer or average value. But after all, 3:03 then it has an amplitude value which 3:05 is greater for a musical signal 3:08 amplitude effective values can be 3:12 in this case measured by the effect 3:16 of transverse recording in deep recording 3:19 results more impressive, this is due to 3:22 less vertical flexibility of the head. About 3:26 what constancy of friction force there can be is 3:29 clearly not the case, now I’ll tell you what 3:33 this inconsistency leads to. With the usual correction angle 3:37 of the tonearm at 22°, a third of the needle's friction force 3:41 turns into 3:50 sliding per second, though sometimes it happens even 3:53 in the orchestra, for such oscillation 3:56 speed the measured addition to the friction force 3:58 is 4:02 15%, the same addition will also be added to 4:28 the sliding.
