Carguy1394
Repair Pioneer A9 NSA.Any help or opinion is welcome
Well yes. I will write what I do while struggling with these amps. Maybe if I manage to repair them for someone then it will be useful. I have already learned a some about the circuit of this NSA amplifier. I'm not sure if my approach is right but practice will show. I also accept any advice except to give up. So if you want to help I appreciate a lot.welcome back ?
Or to ask the exact question: On the amplifier board of the A9 diodes D1-D4, D11-D18 marked in the repair catalog with a star as fast moving items, are the diode 1S2473 which is a fast diode with a time of 1.5 nanoseconds reverse recovery time, isn't it more good to be replaced with an almost as fast diode 637-1N4151 (2 n. second) or with 78-1N4148 (4 n, Sec.) instead of 512-1N4148 (8 n. sec?). Thank youI see that in the forum it is recommended to replace the diode 1S2473 with 512-1N4148. I have a question if some one can answer :
isn't 637-1N4151 or 78-1N4148 a better substitution in terms of speed if 0.2 A is not a problem compared to 0.3A. Here is a link to the data of the original which is with reverse recovery time 1.5nano sec:
https://datasheetspdf.com/pdf/529800/Rohm/1S2473/1
Ok for the notation for the stars, but this does not answer the main question which is: Which diode is the best substitute in general and in this casethe * for "fast moving item" means at the time the service manual was printed, that particular item was popular or they received a lot of orders for it. I would suggest reading the Pioneer Tuning Fork guides that describe the parts that Pioneer used. The Tuning Fork series can be found here at AK or you can down load them from the inter-webs.
Yes .Usually I am using Google speech to text recognition. Or I am writing on a laptop and the mouse pad is so sensitize that switching mi writing on random different places. So I apologies for this inconvenience to every one. Will be glad to correct this. Fill free to ask me what I post wrong and mi pleasure will be to explain.are you using a translation process, some of it doesnt make sense
we have already been through the tuning fork saga aint we
The old tread tuning fork saga I abandoned because no one cared about it. That's why I opened a new tread and made a method by which to fix 4 amplifiers at once. I rely mainly on myself and my engineering experience. There are also a lot of valuable things in this forum. I read all the repairs of similar amplifiers led by Markthefixer and adapt them to my methods or vice versa. So this is a new venture and everything is different. If you want to be in class, what I do do not read the other trade, but only this one. There is also a conversation with another person, but he is ill and appears very rarely, so for now I am fighting alone. I am also in contact with my colleague, an electronics engineer who repairs radars, but he is also super busy. I describe all this with the sole purpose that if I can fix some of these amps there is something that will be useful for people like me. It is.are you using a translation process, some of it doesnt make sense
A long time ago, I was the commander of a sapper platoon in the army, and that's where the word came fromIf you could try to condense what your trying to say to a set voltages or suspected wrong voltages, that would be helpful. Also remember that without referencing or providing a good quality schematic, These numbers and voltages might not mean much to anyone trying to help you.
What translation system are you using?
What language are you typing your answers in? Terms like "Sapper", I do not understand.
Soldering in 1K resistors might not be correct. It might be correct for one amplifier - that does not mean it is correct for another.
Voltages in the schematic are under specific conditions. If a voltage is not correct, it means there is too much current flow (low voltage), or too little current flow (higher voltage) There is a tolerance of all voltages because some will drift based on power conditions depending on where you live and use the equipment. (e.g. I have 253V here, 1 mile away, its 240V - 13V difference causes small differences in voltage in the amplifier)
Is this the one you are trying to repair?
The schematics for the older model can be found here: https://www.hifiengine.com/manual_library/pioneer/a-9.shtml
Perhaps you could state clearly and concisely the issue you are having with the amp you are trying to repair.
